Old 10-10-2010, 07:03 PM
Default Wedico HYD's for dump bodies
Well I am to the point of no return I ripped out the Wedico junk to make room for the screw drive. Once again at a show my black dump truck with the Wedico hyd's started leaking again 2 in less than a year this is just unacceptable yes real 1:1 dumps weep but they are not supposed to leak. We have dump trucks at work when they leak it is time to rebuild them but they do not leak when they are new unless there is something wrong. So lesson learned $350 out the window and in with the $40 screw drive. So before you respond to this yes I know some have had no problems with theirs great for them but I know plenty that have and there is even a guy who rebuilds them when they are new because they are junk.
Old 10-11-2010, 01:13 AM
Default Re: Wedico HYD's for dump bodies
The hydraulics aren't the only things that suck about the Wedicos.
Old 10-11-2010, 09:00 AM
FreddyGearDrive's Avatar
Well Now! Another wedico telescopic cylinder lover! I had 3 of them myself,(had)! I'm now a screwdrive type of Guy.
FGD
Old 10-11-2010, 06:25 PM
LMFAO!!
Old 10-11-2010, 06:53 PM
mine is next , but no screw drive , IHB hydros ( working on it if I ever get caught up on you know what ) I have bought 2 new 1:1 teles never leaked with many hrs on them still no leaks same goes for the 2 used 1's . get this wimpo kit follow instructions for bleeding it . well the pos bled alright , right out the 1st stage like a busted hose the 1st 1's may have been OK but looks like with them mass production = useless scrap
IHSteve
Old 10-11-2010, 11:17 PM
MACK Daddy's Avatar
I guess I am in the minority here than....Although I have only had one Wedico Hydro setup I never had an issue
Alfy
Old 11-25-2010, 08:48 AM
Longhair Longhair is offline
Longhair is on a distinguished road
Do you have a link for the screw drive part?
Old 11-25-2010, 04:20 PM
I make the screw drive myself. Gearmotor threded rod furniture nut delrin and frame rails.
Old 12-03-2010, 10:51 PM
kamyoncu's Avatar
kamyoncu kamyoncu is offline
kamyoncu is on a distinguished road
Personally, my first expericence was in the wdc hydrolic. It was completely disapointment for 4 axle sand-soil load. However It was good in 3 axle rock dumper works. Less load and short dumper lenght
In addition, scaleart hydrolic for U type is almost 4 times expensive than wdc. Yes it is real hydrolic but it is expensive.
My question is that did any body tried to produce boom ? Because simply hydrolic pump production easy and cheap. First you need pump second you need a good motor. the most expensive electric motor around 20-30 $ in ebay.com. the pump about 50 eur in ebay.de. What about boom ?
CAT: 963 B Scaleart // 345D LME Wedico // CS 563 E Handmade
Mercedes Benz: SK 3544 AK 8x8 Premacon // NG 2636 AK 6x6 Wedico Handmade
MAN TGS 26.500 6X6 Wedico - Premacon
MACK Granite 8x6
Old 12-03-2010, 10:59 PM
Trucker Al's Avatar
Well, my first Wedico hydraulic cylinder leaked like a sieve, the replacement is not leaking and has lifted 10 lbs. of pea gravel with no problems. I hope it stays that way.
Alan
Old 12-03-2010, 11:52 PM
Alan
I hope you do have good luck with it they are a neat system when they don't leak.
Old 12-04-2010, 01:03 AM
The wdc telescopes in my KH & pup are ten yrs old, dumped hundreds of loads with the trk, not so much with the pup and both continue to work well today. The telescopes seem to "sweat" a little bit, there's oily grime at the base of each one, but since filling the 110cc custom made reservior ten yrs ago, I have never added oil & they always lift to the top.
On the other hand, it seems wdc's quality has turned to shyt!!! in recent yrs, problems with everything they put on the market... what have they done differently lately? Using poorer grade materials to cut costs & increase profit margins?!
Old 12-04-2010, 12:28 PM
kamyoncu's Avatar
That is why it is there is osswald modelbau, rüst , veroma, bam and all others.
I used wdc hydrolic in 2 year in my garden work 4 axle mercedes truck its dump 1.5 times bigger than standart wdc dump. I add 2 video for it. Here is my garden in 2006. They say much more then me about it
it is full
http://www.youtube.com/watch?v=QvkSsqpa79g
it is half full
http://www.youtube.com/watch?v=6MVBLV5Mt80
MACK Granite 8x6
Old 12-04-2010, 10:48 PM
I prefer a Travis Screw Drive they are reliable no mess and are less than $100.
Old 12-07-2010, 02:54 AM
I have one of Freddy's screwdrives, works great, but I still prefer hyds despite the oily mess... adds to the realism.
Old 02-04-2011, 10:40 PM
roadranger's Avatar
White Line Fever
How about Wedico's pumps? They any good?
I've got one of those pumps from India, but I hear they die after 3 minutes' run time...
what's up with that?
I bought a nice end dump from Ralph Little, he makes his own telescopes, and now I need a good pump to run it... any suggestions?
WILDCAT T&C
Jim B.
Colorado Springs
Old 02-04-2011, 11:14 PM
The pump that comes with the wedico kit is just fine for a telescoping cyl it is just the wedico cyl that I had issues with.
Old 02-05-2011, 01:39 PM
The UMS pump from India was designed for aircraft landing gear. Your dump cyl will go up & down in less than 30 seconds.
The wdc pump works good too.
Old 04-16-2011, 07:18 PM
pigeonfarmboy's Avatar
Good information here. Being in the "what system do I buy" group of newbie isn't so great without comparisons. Pretty sure I'm going with Freddy Dump though.
Old 04-23-2011, 03:53 PM
trucker n's Avatar
i have a question can these be returned to wedico for repair should be a warrenty issue:
