Old 04-21-2013, 01:19 AM
rc semi rc semi is offline
rc semi is on a distinguished road
Default joining two cab to gether
hi guys i want to join two cabs together what should i used to join and bog the body
Old 04-21-2013, 02:44 AM
Default Re: joining two cab to gether
Any solvent based adhesive that melts and welds the joint will work well. Something like Plastistruct Bondene, or Tenax 7R will probably give you the strongest joints. Just be sure you parts fit together tightly, and cleanly before gluing them. These types of glues will not fill gaps.
Old 04-21-2013, 06:02 AM
rappy's Avatar
rappy rappy is offline
rappy is on a distinguished road
are you going to tell us what you doing and bring to the meet at WOT
Old 04-21-2013, 09:56 AM
kaptain Jack's Avatar
What ever glue or solvent you use,don"t forget to reinforce it with flat material behind the seam from inside of the cab.
Old 04-23-2013, 05:33 AM
ok thanks guys yes rappy will let you know
