Old 04-27-2013, 01:50 AM
yhng yhng is offline
yhng is on a distinguished road
Default Turnigy receiver controlled switch
Hi All, i need help
how to wiring Turnigy receiver controlled switch,
i follow the menu to wiring, but not work
Old 04-27-2013, 05:15 PM
woodhog's Avatar
woodhog woodhog is offline
Default Re: Turnigy receiver controlled switch
Best I remember the switch has to have the same ground as the receiver ,try that a nd maybe someone else will chime in . I am using these to turn on a motor on my belt drive with no issues. When i first out it in i was using two batteries and once i got the 2 grounds together it worked fine,then later went to a single battery and still works like a charm. Hope this helps
Woodhog
Old 04-29-2013, 06:07 AM
R.J.F Transport R.J.F Transport is offline
R.J.F Transport is on a distinguished road
if you are using two batteries like in the pic you must have a common ground as specified in the included data sheet
Old 04-30-2013, 03:35 PM
FlyingBeagle's Avatar
Look at the files on the hobbyking page. there is a wiring diagram as a part of the manual that shows a couple different ways of using these.
http://hobbyking.com/hobbyking/store...d_Switch_.html
