Old 05-13-2013, 12:56 AM
Hounddad Hounddad is offline
Hounddad is on a distinguished road
Default Tranny help!!!!!!
Get your minds out of the gutter.
I am building my first semi, a Globe Liner. I didn't wait to put the body on to test the MFU and trans out(good thing).
I am shocked to discover no 2nd gear, 1st and 3rd seem fine.
I believe I followed the directions for proper assembly.
Any help?
Old 05-13-2013, 03:13 AM
RoadFlyer's Avatar
RoadFlyer RoadFlyer is offline
RoadFlyer is on a distinguished road
Default Re: Tranny help!!!!!!
Sort of happened to me...I had no 1st gear. I adjusted the servo link to the transmission and finally got all 3 gears. You might want to try that. Just my 2 cents.
Old 05-13-2013, 08:24 AM
Dairyland Trucker's Avatar
Maybe dabears will chime in on this one because he was just up to the shop last week and one of my show trucks was doing the same thing maybe he can better explain what he found the problem to be.
Old 05-13-2013, 10:11 AM
Check the bushings in the trans to make sure they are all in the right spots and not slipping out. Take the case off the trans and run thru the gears with the motor on. Look for for anything not moving or sliding correctly. I will try to open one up and take a picture of what I am talking about to check. should be the 3rd sprocket from the rear of the trans that is your second gear I belive. Ill double check for you. Also double check the rod from the servo to the trans, make sure it is the right size and adjust if needed just 1mm off and it could give you an issue too.....
Old 05-13-2013, 10:47 AM
Thanks guys.
Will check adjustments.
Thanks for the ucoming pics also, visuals are a great help.
Old 05-14-2013, 02:14 PM
1985 kenworth's Avatar
Red face Re: Tranny help!!!!!!
Yea i am having that problem with my bj's kw i built many and this is the first for.me.thanks i will check mine also
dwayne
Old 05-18-2013, 08:25 PM
Well long story short....Tamiya calls them J6&J8 in the manual, well I apparently switched them.
All seems good now.
Old 05-19-2013, 01:27 AM
Lmackattack's Avatar
It's a common mistake. I just bought a globe off eBay and had the same issue with the trans. Seams they installed the 2 chrome j6-j8 backwards and did not put a cir clip in to hold it. It caused the shift forks to not fully engauge 2nd gear. If your radio has end point adjustment that is another way to fine tune the throw of the servo.
