Old 05-23-2013, 12:48 AM
Lmackattack's Avatar
Default Powering lights from the reciver
Just wondering if it is safe to power lights (LED) from an open channel slot from a receiver? I see that there are a +,- on the reciver cover and it holds a steady voltage.
If it is safe is there a device out there that will plug into the reciver and act as an on/off stitch? For example if I have a 4 channel radio with my 4th channel un used. Is there any way to use that channel to turn my lights on or off?
I'm not interested in the mfu as I just want a simple on off function
Thanks for any help.
Old 05-23-2013, 01:08 AM
CG Bob's Avatar
CG Bob CG Bob is offline
Default Re: Powering lights from the reciver
Yes, it is safe to power LEDs from an open slot on your transmitter; you'll need to install a resistor in the line between the receiver plug and the LEDs. Most LED have a max rating around 3 volts, anything over that will fry the LED. There are electronic switches that can plug into the receiver and power on or off various optional equipment.
I know of several LED light kits for aircraft that incorporate a switch with the light unit; most of the aircraft LED kits have flashing red and green LEDs as well as steady on (solid) white LEDs.
Old 05-23-2013, 01:48 AM
Ok thanks for answering my question..I added 9 LEDs to my cab and pulled power from the reciver but didn't think to check if that was to much for it.. I used a resistor on all leads and it worked great. I will be adding trailer lights soon and did not want to go thru all this trouble to find out I could fry something...
I will look into that switched power
Thank you again
Trent
Old 05-23-2013, 03:40 AM
Brel's Avatar
Brel Brel is offline
I have powered the Headlights on My Robbe Linde H50 fork lift truck model from the receiver using the battery connection to power the light and a Picoswitch and used the fifth channel on the TX to turn them on and off
Old 05-23-2013, 12:38 PM
thanks guys.. I searched for a pico switch and found these items.
pretty cheep too!
http://www.dimensionengineering.com/...s/battleswitch
Old 05-28-2013, 09:16 AM
Diesel Demond's Avatar
thats the exact one i have and works great with my rds 8000
