Old 06-15-2013, 09:42 AM
cosworth34677's Avatar
Default slipping rubber tracks?
hey is there anything i can put on the drive wheels on the a bruder mini excavator with rubber tracks to ads some traction. they tend to slip when im trying to turn.
i was thinking of adding thin layer of silcon.
Old 06-15-2013, 11:54 AM
Default Re: slipping rubber tracks?
Cossie:
Option #1 : some heat-shrink tubing, carefully applied, then roughened with sandpaper.
Option #2 : some of that anti-skip floor tape (looks like black emery-paper tape)
Option #3 : See if there is a way you can put a drive sprocket in the drive wheel, and then punch some drive-holes in the rubber track. Think like the sprockets on a bicycle (RobotShop probably has ones you could use...)
Option #4 : Replace the track altogether, perhaps with some track and drive sprocket from one of the HL Pz 3, Pz. 4, or M41.
Just tossing options...
Old 06-15-2013, 12:41 PM
thanks i like option 1 and 2. seem to can be done easy without any major redesigning
Old 06-15-2013, 12:52 PM
*nods*
And buying a roll of the anti-slip tape, if/wjhen it peels ow wears out, you can re-apply it!
If ya go the heat-shrink way, be careful ya dun warp th drive wheel getting the tubing snugged down. Heck, even some thin rubber tubing snugged over the rin might do (like a slice of inner-tube from a 10-speed tire, or such...)
Always ready to think outside the box...
(and who sacly won't make either of the Southern Ontario meets in June... *sigh*)
Old 06-15-2013, 01:48 PM
Rvjimd's Avatar
Rvjimd Rvjimd is offline
Cos,
When you figure this out would you mind posting a closeup picture of your solution?
This sounds like the sort of thing that may be useful in a lot of other similar applications.
Jim
Old 07-23-2013, 03:47 PM
rc_farmer's Avatar
Master Builder
Glue some sandpaper to the drive wheel.....works on my Cat tractor
Giving up is not an option!!!
