Old 07-21-2013, 06:20 AM
rc semi rc semi is offline
rc semi is on a distinguished road
Default rc4wd excavator ?
hi guys dose any one have a rc4wd excavator or know if there any good thanks
Old 07-21-2013, 09:27 AM
IDontKnow's Avatar
Default Re: rc4wd excavator ?
I have one and have found it very well made.
I did have a faulty speed controller for the hydro but that was sorted relatively easy.
Battery life is pretty good, just need to make sure you have a decent battery.
For shows we put on, I have set up a power supply with some leads with the deans type socket on the end and power two machines off that. Went most of the day without an issue, filled about 10 x 20 litre buckets of kitty litter. Fill the bucket .... empty it out ... fill it again.
Regards,
Bill Randall
Perth, Western Australia
West Coast Remote Control Trucks Inc
It's time to get out of the rut and get into the fun!
Come visit us at
Old 07-21-2013, 01:37 PM
Dieselchopper's Avatar
Mine has been good. Made a large bulk material bucket and a smaller ripping bucket. Some minor oil leaks but performing well.
Old 07-22-2013, 10:34 AM
CrewCab59's Avatar
CrewCab59 CrewCab59 is offline
CrewCab59 is on a distinguished road
Here is some info plus a few vids in link.
http://www.rctruckandconstruction.co...ead.php?t=2425
A1 Dirt A1 Dirt is offline
A1 Dirt is on a distinguished road
I have a 4200XL and am happy I bought it. I had an initial problem with the pump and pump motor, but RC4WD sent replacements. I only have a few hours on it since installing the parts, but have had no other problems.
Old 07-22-2013, 09:37 PM
woodhog's Avatar
woodhog woodhog is offline
Mine has been pretty good also,my stick cylinder is bypassing oil but other than that it has done ok. I now have changed the hydros over to Leimbach,valves also and put a dx18 to control it.I also changed the engine house and cab to make it more 1:14 scale . I have a guy here that can make cylinders out of stainless and the packing will be made like real cylinders are instead of o rings for the rod packing.I don't know if the hydros will push it yet though its still being made.The rc4wd cylinders have anodizing on the inside that is wearing and letting oil bypass. The inside only has one oring on the rod so it can't take a little wear.I know a bunch of yall have had no problems and some have had a lot of problems.I guess its a catch 22. The second version is definitely a better machine.I am happy with mine.
Woodhog
Old 07-23-2013, 12:38 PM
i set one up for someone and ran it quite a bit. i know 3 people that have them and are very happy with them. It is a nice solid machine. The pump draws a lot of current because the pump is about 4 times the power necessary to run that size machine but, it doesn't hurt anything as long as you turn the pressure down.
You should lower the pressure so that the boom has just enough power to easily lift one side of the machine up.
