Old 07-22-2013, 02:07 PM
dmess62's Avatar
dmess62 dmess62 is offline
Default Mfu throttle help needed
Having issue with the throttle being reversed. When I push the left stick up th truck goes in reverse when pull stick down truck goes forward but back up beeper sounds. If I go int to settings and reverse throttle then the truck goes forward when I pull stick down also the throttle cut is opposite when I push it the truck accelerates. I'm using dx6i. I ve searched and haven't come up with answer yet, anybody have any suggestions
Dave
Old 07-22-2013, 04:09 PM
Default Re: Mfu throttle help needed
Switch your main power wires to your motor. There's no positive and negative terminals to worry about seeing as the motor turns both ways.
If you have a brushless motor, I know nothing about them and not sure if they have a polarity requirement or not?
Mario
Old 07-22-2013, 07:02 PM
dmess62's Avatar
Seemed to have worked. Now it keeps shutting down. Can't win for losing
Dave
Old 12-08-2013, 10:40 PM
Did you resolve issue? Sometimes you have to re calibrate the MFU through the steps in the book
