Old 08-20-2013, 08:05 AM
Ramon's Avatar
Ramon Ramon is offline
Ramon is on a distinguished road
Default Volvo SD200 Compactor
I started with a new project a Volvo SD compactor.
Scale 1:14,5, weight +/- 6kg. ø roller 110mm
the laser cut parts.
The tires ø 110mm
The drive motor in the back.
The drive motor in the roller with the vibrate unit on top.
Old 08-20-2013, 12:41 PM
rc entreprenøren rc entreprenøren is offline
rc entreprenøren is on a distinguished road
Default Re: Volvo SD200 Compactor
And this to..you are simply a pro.
Old 08-20-2013, 12:44 PM
If you should make me one like this. Not assembled, in parts, could you say a price..ich....
Old 08-23-2013, 04:44 PM
Stefan Stefan is offline
Hi Ramon!
Another Volvo! And you rarely see a scale compactor. Two excellent choices! (Anyone built a paver yet?)
Stefan
Old 08-24-2013, 12:51 AM
Very nice project! You have my attention, and I'll be checking for updates.
Old 08-24-2013, 09:04 PM
Is the rear axle solid? You might need a differential to make it steer. With it locked it may not turn.
Old 08-25-2013, 03:57 PM
Finster's Avatar
Finster Finster is offline
Unique build and great start so far. Looking forward to updates.
Old 08-28-2013, 09:38 AM
Ramon's Avatar
The rear axle is solid, I did a test run with it and ste steering is no problem.
Old 08-28-2013, 09:52 AM
Ramon's Avatar
The progress so far.
The front unit without the roller.
the Chassis ready for gluing. I use the UHU endfast 300 glu and then for 5 min at 150 degree in the oven, super strong.
the chassis and front unit.
the cabin just before gluing. Made from 2 parts 1mm aluminium sheet, bended in the panbrake folder.
Old 08-30-2013, 12:57 PM
rc_farmer's Avatar
Master Builder
Very interesting, i wil definitely be watching this one to the end
Giving up is not an option!!!
Old 09-03-2013, 07:25 AM
titandigs's Avatar
Aussie Fabricator
looking good Ramon I like the fine work on the cab
Old 09-03-2013, 07:43 AM
ptebbe ptebbe is offline
Great project. I can't believe you use glue to assemble! I've never heard of that glue...how does it compare to JB Weld?
Paul
Old 09-03-2013, 08:02 AM
Ramon's Avatar
Paul
UHU plus endfest 300 2-K-Epoxidharzkleber.
http://www.uhu.com/en/products/epoxy...oxidharzkleber
It is possible to put this in the oven for 7 min on 150 degrees the glue get stronger when you heat it up , up to 3000n/cm2.
If you have to glue another part to the part that is glued the glue will stay strong. dont overheat or leave the parts longer than 7 min in the oven.
after the glue cooled off you can sand it drill in it and paint it.
It is not possible to powder coat the glue.
I used the glue on al my models and some are 8 years old and no problems.
I dont have the option to weld or solder the Aluminium so this glue is perfect.
Old 09-03-2013, 08:32 AM
Ramon's Avatar
Making parts on my new Stepcraft 420 CNC milling machine.
The result so far.
next step is the details on the body work.
The grey air filter is a top of a after shave bottle
Old 09-03-2013, 09:11 AM
diesel950 diesel950 is offline
diesel950 is on a distinguished road
looking better and better ramon
Old 09-03-2013, 09:31 AM
Very nice!
Old 09-03-2013, 11:52 AM
Snochaser's Avatar
Awesome work. Looks terrific.
, you will not be forgotten.
R.I.P. FGD
Work Hard, Play Hard!
Never Forget- 343
Old 09-04-2013, 06:55 AM
modelbouwer modelbouwer is offline
modelbouwer is on a distinguished road
Hallo Ramon
Super de modellen van je
verder is alles goed met jullie
gr Martin Wezel
Old 09-04-2013, 01:57 PM
Wow. This is turning out incredible! Your cab is amazing. Is it separate pieces off your CNC mill, glued together as well? The fit and finish is amazing. The whole compactor looks flawless right now.
Old 09-04-2013, 04:20 PM
very nice looking machine. I like your setup of the powered roller.
