Old 10-05-2013, 12:20 PM
bhaagjr bhaagjr is offline
bhaagjr is on a distinguished road
Default Questions on new frame rails
I am working on a new King Hauler that I would like to do some modifications to. I bought a set of frame rails and air ride kits from TRUESCALE. I have a couple of questions from the experts out there.
1. What size drill bit are you using for the 3mm threaded holes?
2. What is the best way to drill the rails. Do you secure them together and drill the holes in both rails at the same time?
3. When you start building the truck do you start with the front suspension and work to the rear, drilling and mounting the accessories as you go?
THANKS FOR THE HELP...Buddy
Old 10-05-2013, 11:49 PM
rc_farmer's Avatar
Master Builder
Default Re: Questions on new frame rails
drill bit is a 2.5mm (if you buy a package, u get the bit and tap together)
Make sure you measure 4 times before you drill ur holes and lay out your accessories before you drill any hole. Test fit your cab and make sure everything will clear eachother.
Most everyone buils the roolling chassi first, then start adding other accessories
Giving up is not an option!!!
