Old 10-12-2013, 11:30 PM
konajoe konajoe is offline
konajoe is on a distinguished road
Default Agricultural/Tractor tires
Hello everyone,
Sorry if this may be posted in the wrong section.
I'm working on a RC project and require a set of Aggy/Tractor tires in the 5" to 6" height range. I've looked around and have found some stuff on a few German pages but are unsure of the quantities, price etc. Does anyone have any experience purchasing from these vendors or can recommend a particular place to check out?
Thanks,
Old 10-13-2013, 10:32 PM
rc_farmer's Avatar
Master Builder
Default Re: Agricultural/Tractor tires
Do you have a pic of the type tire ur looking for?
Giving up is not an option!!!
Old 10-14-2013, 12:17 PM
There are some decent, although wider, v-treaded monster truck tires, readily available, inside the USA that may work for you. They are designed to fit on a standard 2.2 sized rim. Traxxas and HPI both have a good looking tire in this size. If you were feeling ambitious, you could probably narrow these tires up to make them more scale, although some of the bigger articulated 4x4 tractors do run some rather wide singles like these, instead of duals. In North America, narrower duals are more common, but there are some tractors fitted with wide floatation tires as well. Think forestry sized. Narrowing up a set of tires is something I have never tried, but the rock crawler guys do it all the time. Doesn't seem like it's to hard to do. You cut the tire in half and remove some width from it, then glue it back together.
Here are the HPI tires -
http://www3.towerhobbies.com/cgi-bin...P?I=LXPZV5&P=8
And here are the Traxxas tires -
http://www3.towerhobbies.com/cgi-bin/wti0001p?&I=LXJK61
I bought a set of each of these tires. I like both, but the HPI tires are slightly taller then the Traxxas tires. Scale-wise, Traxxas tires have no writing on the sidewall, which is kind of nice. HPI has some molded on Mud King lettering, which may or may not bother you. Both of these tires are a good size for tractors in 1/16 scale. I favor the HPI tires a little more because of the extra height, and because they are slightly softer.
Old 10-22-2013, 04:27 PM
Hi joe!
Have you already looked at "Dakotahtoyparts"? Trelleborg ans Firestone in 1/16...
http://www.dakotahtoyparts.com/web/index.php?siteid=313
regards,
Frank
Old 10-22-2013, 06:24 PM
foub01 foub01 is offline
foub01 is on a distinguished road
great site.never found them before.do you know if the tires are soft or really hard rubber? wonder if they will ship to the uk? must ask
Old 10-23-2013, 02:49 AM
The Firestone 30,5-32 , 24,5-32 and Trelleborg will be ok for a conversion...
In our club we have the Trelleborg on a Steiger.
regards,
Frank
