Old 10-21-2013, 06:50 AM
Rckcrwlr's Avatar
Rckcrwlr Rckcrwlr is offline
Rckcrwlr is on a distinguished road
Default Rckcrwlr's KingWorth
Always wanting one and watching Joe (xj man) building his, I had to do it.
I had a set RC4WD Wheels and just ordered there new grill.
Can't wait to get this thing rolling...
Old 10-21-2013, 06:51 AM
Rckcrwlr's Avatar
Default Re: Rckcrwlr's KingWorth
I decided that this is going to be a Day Cab Kenworth...
So first thing I needed to do is "cut" the sleeper cab off...
I wanted the older style look like this one
So I needed to get rid of the molded in headlights.
Next will be patching and sanding the fenders down...
Old 10-21-2013, 06:52 AM
Rckcrwlr's Avatar
Gathered up all the stuff I needed...
Plastic Weld
Lexan Scissors
Xacto Knife
Body Filler
Now it was time time fix these fenders.
First thing I did was get some thin, flexible styrene sheet to attach to the back to keep the contour of the fender and to close in the hood
I then cut two pieces to fill in the top part and used the PlasticWeld to adhere it.
Time to dry.
Old 10-21-2013, 06:53 AM
Rckcrwlr's Avatar
I then started on the back where the sleeper cab was attached.
First thing I needed to do was clean up the edges and cut a piece to fit it there as good as possible.
Using tabs to hold the panel, I glued it in place...
Then needed to add the rear window.
The King Hauler has a Panel on the roof that I do not like. Looks like a sun roof that never was.
So I glued it in place and covered all the mounting holes so I don't fill them with putty.
Old 10-21-2013, 06:55 AM
Rckcrwlr's Avatar
It was now time for filling in the gaps and lines.
For the fenders, I needed to make sure that I added a little more than needed so I can sand the curve of the fender.
Next was the roof. You can see why I used tape to cover the accessory mounting holes...I would have had to clean everyone out.
The back is going to be the hardest. I am thinking I will be doing two coats on it.
It is now in the paint booth drying...this putty stinks... :confused0068:
Old 10-21-2013, 06:56 AM
Rckcrwlr's Avatar
Shot the body with some primer to I can see the parts that need another coat...
Here's the roof after a sanding
Fenders are not bad...well the right wasn't...left needs some help
Put a thin skim on and should be all I will need...I hope
Old 10-21-2013, 08:09 AM
Mikem Mikem is offline
I'm almost doing the same but cut the fenders completely off ,but I have a question where are you putting the battery . Thanks .mike
Old 10-21-2013, 08:37 AM
Rckcrwlr's Avatar
Originally Posted by Erick O View Post
is that the 3m putty if so I hope it doesn't break out on you that stuff doesn't like Styrene I have to completely redo my W900A hood because its blowing out and cracking around the edges.
I'll have to see what it is. I have used it in the past with no issues...
I have to see...was thinking of building a tool box behind the cab for it. I saw a cool one the other day that I may try to build...
Old 10-21-2013, 10:40 AM
Nice job friend
Old 10-21-2013, 12:18 PM
Mojave450rider Mojave450rider is offline
Mojave450rider is on a distinguished road
off to a nice start!
Old 10-21-2013, 03:06 PM
looking great!!
Old 10-21-2013, 06:09 PM
Finster's Avatar
Finster Finster is offline
Nice job, I like the colors so far...
Old 10-22-2013, 02:21 AM
RCKiwi RCKiwi is offline
Nice build and nice execution - keep up the good work
Old 10-22-2013, 08:20 AM
Rckcrwlr's Avatar
Originally Posted by toniolillo View Post
Nice job friend
Originally Posted by aussietruckerguy View Post
looking great!!
Thanks guys...This is a slow build with all the other stuff going on.
Going to start on the utility boxes. Need to make sure I can get a decent size battery in there.
Old 10-26-2013, 08:54 PM
Trucker_Jo's Avatar
I like the rear window trim Any updates?
Old 10-26-2013, 09:33 PM
Rckcrwlr's Avatar
Thanks....nothing yet. Hoping to get back on it next weekend.
Old 01-09-2014, 05:29 PM
Rckcrwlr's Avatar
After being disappointed with the body work...it went back in the shop...
King Worth is now changing directions...so with that starts a new thread...
http://www.rctruckandconstruction.co...ead.php?t=8187
