Old 10-29-2013, 08:57 PM
cosworth34677's Avatar
Default help with a fix!
ok i got a mangon hrc hydraulic pistion the leaks at the front.
i opend it up and the little weird looking oring is torn. the o-ring is brown
and it has a small spring that sits around to opening that the piston slides through. what is the seal called? ive seen them on my old ford escort. and it
seem that the only thing wrong with the piston. i can't get a picture it's put together and on the excavator. i'm thinking this is not a one off part so if anyone know what thats called or where to get them let me know .
Old 10-29-2013, 09:03 PM
Default Re: help with a fix!
found it its a oil seal ring. still wonder where to get them
Old 10-29-2013, 09:20 PM
Lmackattack's Avatar
Try mc master Carr.com
if your lucky it will be a standard sized "ORV" numbered oring
Measure the cross section, OD and ID
Most Hyd rams have a dust seal,fluid seal, guide rings, and du bushing
Some simple versions just have a single o ring to seal in the fluid.
I rebuilt many of this things over the years
Old 10-29-2013, 09:45 PM
Originally Posted by Lmackattack View Post
Try 232,00 €
i think i orderd the right thing ? it was only 5$ so heck if no i'll do something with them
