Old 11-11-2013, 11:13 AM
rsd53 rsd53 is offline
Default Transmission options
I'm trying to get an idea of what you guys would recommend for a transmission for my Tonka conversion. I have a stock Tamiya motor and 3-speed transmission, but I won't have enough room inside the cab to use them.
I'm looking for something I can use a 540 motor with, that is shorter in length, height, and isn't too expensive.I haven't had much luck with the vendors sites, when it comes to price.
Thanks, Rob
Old 11-11-2013, 01:06 PM
Default Re: Transmission options
Rob check out RC4WD for a transmission they have a 2 speed that is fairly compact. Ed
Old 11-11-2013, 05:20 PM
HD semi version (new) http://www.wtbcar.com/shopping/index...product_id=203
what I have in mine - http://www.wtbcar.com/shopping/index...product_id=154
or try a rc4wd dig tranny?
Old 11-11-2013, 08:24 PM
Ed, that one is on my list, but a little more than I want to spend. I do think it would be a great fit though.
Old 11-11-2013, 08:29 PM
Thanks for the links. I really like the looks of these, and the low profile they provide. however both are on the upper limit of my budget. I had never been on that site before, but I do plan on checking them out more thoroughly.
Old 11-11-2013, 09:26 PM
I've also been looking at the RC4WD planetary transmissions. If I coupled a 16:1 with a 65t motor, I would probably have all the speed I needed.
Is anyone using one of these?
Old 11-12-2013, 08:23 PM
A bit different approach here - but take a look at some of the robot shops - they carry electric motors with gear reduction units already attached. sometimes they are more affordable. but they are generally more compact.
Old 11-13-2013, 06:24 AM
Izzy, that's a great idea, and I will start looking into that option right away.
Old 11-23-2013, 02:28 PM
I too would suggest looking at the planetary style gearmotors. You might even consider robbing such a set-up from a cheap power screwdriver, or an old cordless drill. You could run a rear axle, using a driveshaft with that set-up, or you could also drive the wheels directly off the output shaft of the gearmotor, although then you will one motor for each wheel you wish to power.
Old 12-16-2013, 03:44 PM
Rimrock Rimrock is offline
Servonaut planetary gearmotors are strong, quiet and compact. Over here in the old world a lot of folks that are into RC trucks, quickly throw out the noisy, backlashing Tamiya 3 speed, and it's motor which is more suitable for Formula 1...Most popular is the GM32U370, 7.2 V and output speed of about 370-400 rpm. (The speed with a standard 1:2.666 differential with equal 2'nd gear on a standard Tamiya 3 with a motor turning 6-7000 rpm, as of e.g an LRP Truckpuller) Will give a speed of 1.5 mph, which many find very suitable, and have no trouble dealing with total weights of 50-60 lbs. there is also the GM32U450, 12 V, which got double power. Costs about 100 USD. I don't know if there are any dealers over there, or what shipping cost from Germany. Will be cheaper disassemble a battery screwdriver, if one comes over one with a suitable rpm. About 150 rpm on the wheels of Tamiya 1:14 size tires gives the 1.5 mhp speed..
Old 01-22-2014, 12:49 AM
ricm ricm is offline
My vote would be a pre-assembled gearmotor as suggested by Izzy - absolutely right to look at the robot parts suppliers....
try http://www.technobotsonline.com/
these guys have a HUGE range to suit pretty much anything. And pricing is pretty good
Old 02-10-2014, 05:52 PM
RodneyO's Avatar
RodneyO RodneyO is offline
RodneyO is on a distinguished road
has anyone used this transmission in any of there builds?If so what is your opinion on it?Thanks
Old 02-10-2014, 06:52 PM
I have a 14:1 on the way from korea. I'll see what it's like when it gets here. might be too slow at 14:1 for drive motor but it is intended for my lift. there is a lower reduction to which might be what the RC4WD ones are.
Old 02-10-2014, 08:02 PM
RodneyO's Avatar
Thanks.I've seen a 1:5 ratio one also on eBay.I'm running a 45t motor from rc4wd.Appreciate you giving me your input.
Old 02-11-2014, 07:41 PM
A 4:1 or a 5:1 is a good auxiliary reduction box to add to another main transmission, but you'll want a lot more reduction than that, if you are thinking of replacing a Tamiya 3 speed with a more compact planetary or spur gear transmission.
Old 02-13-2014, 11:12 AM
RodneyO's Avatar
Ok.Thanks.I'm looking for something a little more compact to replace the 3 speed that I have in my KH.Looked at the links on here and was thinking of running one of the robot planetary ones.Just don't know which ratio to go with.
Old 07-28-2014, 08:15 PM
PaulNZ's Avatar
PaulNZ PaulNZ is offline
PaulNZ is on a distinguished road
Hi All
has anyone fitted a 2 speed either in front or behind a 3 speed?
if so what did you use?
Old 08-16-2014, 12:46 AM
oldracer oldracer is offline
oldracer is on a distinguished road
can you or some one tell me where i can get a drive shaft center support bearing, thanks oldracer
Old 08-16-2014, 09:57 PM
Check out the hobby shop section here on the forum, there are a few available there
Old 01-26-2015, 12:11 AM
RoadFlyer's Avatar
RoadFlyer RoadFlyer is offline
RoadFlyer is on a distinguished road
I just put one of these into my Knight Hauler. Tried it first with a RC4WD 80 turn modified Crawler motor...a little too slow. Next put the original 540 Tamiya motor that came with K.H...runs great. I've got 2 speeds instead of the stock 3 speeds. These planetary gears are much quieter than the stock 3 speed Tamiya transmission and a lot smother. I would recommend this as a must do for all the Tamiya truck line.
