Truck Building Tech Covers mechanical and electrical components for truck modeling |
This thread is for posting pics of trailers and what you used to build it. Questions are encouraged.
Here are some pics of my home made trailer parts. Quad axle lowboy frame and suspension ![]() ![]() ![]() ![]() ![]() Pup dump trailer ![]() ![]() ![]() Two box trailers turned into single axle pups. ![]() ![]() ![]() ![]()
AKA "00" Biddle RIP FreddyGearDrive 2-12-59/12-19-11 Last edited by Tamiya Cowboy; 10-31-2010 at 09:21 PM. |
Flat bed converted to a dump trailer.
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Travis
AKA "00" Biddle RIP FreddyGearDrive 2-12-59/12-19-11 |
Here is a pic of it hooked to my tri drive Areomax and this trailer gets a new home next Sat. Doug (firefighter30) bought it. I sold it to get some money to start a new one.
![]() Thanks Travis
Heres a few pics of trailers
modified flatbed now Drop deck - another fella had posted this kind of build previously - lower bed is a full flatbed - the upper is just longer than the jack legs. ![]() ![]() ![]() ![]() ![]() My Dump - on a Box trailer frame (rails flanged outward for space) - the upper is all styrene and it has a 2 part extending thread drive - Double Tamiya suspension, on sub frame ![]() ![]() ![]() ![]() ![]() ![]() LowBoy - aluminum frame with double steel arch stiffeners and steel front neck - aluminum is from Lowes - 2 sizes - neck uses Tamiya 5th wheel plate for quick attach ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Modular Home Frame - All steel with custom length Wedico Axels ![]() ![]() ![]() |
here's some pics of my low-boy now if you don't have access to a mill to make the I beam frame you can always weld it ,braze or solder what ever you have available . Just takes some patience
![]() ![]() ![]() I'll try to get more up in my build tread http://173.201.47.108/showthread.php?t=51 IHSteve
Mike - thanks for the compliments ......
The dump was made using CA glue. Since then I have discussed it with Travis - should have used styrene weld - I believe the joints would be much better. There are weak joints but none have popped. It has only seen the crushed rubber. I believe it to have enough power for dirt though. If you are familur with the Sand MAster units - it takes three whole hoopers to fill it. ![]() ![]() On the low boy - I copied the pictures of a trail king into a cad program then drew over top - so the lines are there's - the details are a bit different though. Here area few more pics of the workings of the neck..... I'll look for a video of it in action - several people have taken vids over hte past two years - many don't share though....wonder why??? ![]() ![]() ![]() ![]() ![]() |
i have a flat bed trailer costume built by freddy and i am looking on how to secure 1/16th scale john deer tractors to the trailer with the stock flat bed chains. i have 3 tractors to hold tight to the trailer any help would be great. now the trailer has 5 loops on the side of it allready to pull chain through it but i cant figure out how to pull them tight and keep them tight . also i am 2 loops short so i need to think of another way to tighten them down. any help would be great thanx cory!
Grabbin gears and Rollin wheels ! LETS BLOW SMOKE!! Member of the Central Plains Mini Truckers,and a Minnesota road hammer. To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. Flat bedders do it with chains and straps,but now im yanking 53's To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. |
Oh I see Izzy, you used a fifth wheel on the bottom of the neck... That works for sure.
The real things have a surprisingly easy attachment method. The trailer really looks good. Congrats.. ![]() -Mike
To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. Mike "DREAMWEAVER" Johnson To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. RIP FreddyGearDrive 2-12-59/12-19-11 Rims and Tanks by ihbuilder / Grill and Visor by Brian in PA / Mirrors, Front and Rear Bumper, Back of Cab Lights, and Steering Arms by tc1cat / Fenders by Stylin n Profilin / Frame Rails by The Late Freddy Gear Drive |
![]() Quote:
![]() Quote:
![]() Travis
AKA "00" Biddle RIP FreddyGearDrive 2-12-59/12-19-11 Last edited by fhhhstix; 02-26-2011 at 11:44 PM. |
![]() Quote:
"Experience is what you get right after you needed it." |
Mike - check out IhBuilders home built - he is working on a really scale attachment method - very realistic..... Also if you had a chance to get a unit out of PMD - they are very realistic as well - especially if you spend the extra bucks for the hydraulic unit.
Tanker Yanker - I would strongly suggest the turn buckle concept - nice and secure - the over center binders from PMD work but are very delicate - but are fabulous for detail. |
how did you make the axels for low boy travis? They look like a great affordable option.
All the trailers look great guys, very inspiring I wish I had more time to build. |
They are delrin tube with a thin brass tube inside and an aluminum axle shaft for the bearings in the wheels to run on. For the rims I driled out some plastic hex hubs and inserted a flanged bearing and drilled out the out side rim to hold another flanged bearing so each set of rims has two bearings an outer and inner. I then threaded the aluminum axle for 3 mm screws to hod the wheels on. I will post some pics in a minuite.
Here are some pics.
Sweet. Thanks Travis, I might have to borrow that idea if ya don't mind.
No problem and good luck with your build.
![]() Travis
Travis This question is directed your way. First thanks for starting this thread ,as there's going to be lots of question coming your way. First one is, You seen to have used lots of different all thread sizes, does that depend on the load weight or the length of stroke for the slider. What rpm gear drive and torque power seems best. Whats the best lift action, to push from the front to the back, or back to front. That's it for now. Thanks
I use 10/32 in all of my builds but the dump trailer and it is 3/8 fine thread. The dump trailer was my first screw drive and I did not think about the fact that the sliding block would carry the load and the all thread just had to move it. All of my screw drives push from back to front. For gear reduction my traler is 32:1 with a 65 turn 540 lathe motor the two dump trucks are 50:1 carson gearmotors and the dump pup trailer is a black & decker $10 screw driver from Wall-Mart.
![]() Travis Quote:
Currently Active Users Viewing This Thread: 7 (0 members and 7 guests) | |
