Old 12-16-2013, 06:06 PM
smolden52 smolden52 is offline
smolden52 is on a distinguished road
Default sluggish hydraulics wedico 345d
My lovely "new" 345d excavator had somewhat slow hydraulics when I got it 6 weeks ago , and now they are even slower. The main boom is really slow.
I expect the hydraulic pump motor is going bad. Or maybe the pump itself. I know I've seen the pump motors for sale.
Thanks for any input......
Old 12-16-2013, 09:08 PM
steamer's Avatar
steamer steamer is offline
Default Re: sluggish hydraulics wedico 345d
Just a thought but did you remove the vent line off of the oil tank. Sometimes they tie the two nipples together with a piece of hose so it doesn't spill oil.
Old 12-17-2013, 01:31 AM
How's the oil level?
a picture would help a lot.
Old 12-21-2013, 02:55 AM
Rimrock Rimrock is offline
I guess that Wedico uses the Leimbach hydraulics, which are in general of good quality. A 345 size machine is pushing the limits of the capacity of the Leimbach equipment, but with things finetuned it should operate just fine.
Here are some more ideas;
* Check that the servos will open the valves maximum in both directions (may be adjusted by trim functions)
* Check for contaminant particles in the hydraulic system (filter and so on)
* If the oil level is a bit too low, there can come air in the system, that may slow things down
Is all of the oil the original? If you by any chance have have added some thicker oil into it, that may result in more slow operation.
Old 12-21-2013, 03:24 AM
Factory new hydraulic may in some case have some small metal contaminants left from the production process, that have not been fully removed. If just a tiny-tiny item gets stuck e.g. in the pressure relief valve, one may never get a good pressure build-up. This valve is a part of the pump, and one needs a manometer hooked up when to reinstall it again, to get the correct pressure setting.
Old 12-21-2013, 04:10 PM
Actros4160's Avatar
I had also some issues with my hydraulic. The center valve body was moving only at normal speed in on direction and after a couple of seconds in they other direction. I found small debris in the valve and the valve rod.
Old 12-24-2013, 11:06 AM
Actros4160's Avatar
How much pressure is in the system?
