Old 12-20-2013, 10:45 AM
baker3 baker3 is offline
baker3 is on a distinguished road
Default Turnigy 9x for dozer questions
Anyone using this radio with info is greatly appreciated. I am trying to mix channels to control all steering and throttle from the left stick. I have my ESC's for the two servos plugged into the CH1&2. So far I can get both tracks to move forward and back but unable to steer. Any help? I am a complete noob to this area
Old 12-20-2013, 02:09 PM
Default Re: Turnigy 9x for dozer questions
The only suggestion I have is to use a Sabertooth controller, they have the mixing built in,
http://www.dimensionengineering.com/...abertooth2x5rc Hope somebody else will chime in too!
Old 12-20-2013, 03:16 PM
Your radio came with a manual, did it not? Look under channel mixing.
Tip: the throttle channel is Master and the steering is Slave. It'll be +100 & -100.
I've never owned a Turnigy radio. For my Spektrum radio, if it's steering the wrong way, then I can either switch the + & - values or reverse the travel of steering ch itself.
Old 12-20-2013, 06:01 PM
kenobi kenobi is offline
kenobi is on a distinguished road
This may be of help, there are tons of them on YouTube
http://youtu.be/YNx9DHySD9A
Old 12-20-2013, 07:39 PM
TURN ON RADIO
go to display. using your display find out which stick operates your
RUDDER AND ELIVATOR. Change stick type till you get then where you want them.
Go to V-TAIL
State = ACT
ELE1 = -100
ELE2 = 100
RUD1 = 100
RUD2 = -100
Go back to display and watch how they work.
Cheers Chris.
HMMMMM! all this programing makes my radio a dinosaur
Old 12-28-2013, 05:42 PM
TURN ON RADIO
Go to V-TAIL
State = ACT
ELE1 = -100
ELE2 = 100
RUD1 = 100
RUD2 = -100
Cheers Chris.
I tried what you said and I still cant get it. I have the left track running off channel 2, Right track off channel 3 and the rams are controlled with the Rudder and Aileron. Do I have to plug the tracks into an Aux slot?
Old 12-28-2013, 06:11 PM
Brel's Avatar
Brel Brel is offline
have look at this forum http://openrcforums.com/forum/index.php (you may have to register) they have lots of stuff on there about the 9X radio
Old 12-29-2013, 08:57 AM
kaptain Jack's Avatar
That's not exactly what you looking for,but still can be usefull
http://www.youtube.com/watch?v=Oi7jRcsfXB8
Old 12-29-2013, 10:24 AM
So for anyone having similar troubles, I finally figured it out. I have my radio set to "acro". I then set the stick type to the Rud and Ele to use channels 2 and 4 which my tracks are plugged into. Then as Oztruck said, go to V-Tail and adjust the parameters to what he said.
