Old 01-12-2014, 04:18 PM
Bg416 Bg416 is offline
Bg416 is on a distinguished road
Default Having some trouble. (Pics inside)
I have my bruder excavator going well until I hooked my pump esc up. The motor works with power straight from a battery but not when it's hooked up to the esc. I have my mixings done on my turnigy 9x and I'm pretty sure it's right. Am I doing something wrong?
Old 01-12-2014, 04:43 PM
Default Re: Having some trouble. (Pics inside)
I don't see the receiver or the battery in the picture, is the esc plugged in to the rx or batt?
Old 01-12-2014, 04:45 PM
yeah i just noticed the picture now.. i just put the esc in just for the picture. the esc is plugged into ch7 and the battery is plugged into the esc.
Old 01-12-2014, 06:26 PM
cosworth34677's Avatar
servo's are missing the valves . also just from a old school r/c guy, you should har wire the motor to the esc, its little better on the old esc and battery. every solder joint and plug is a little bit of
power lost, and can be a hot spot in the circuit
Old 01-12-2014, 07:10 PM
I plugged a servo in just to see if that was the problem and it still didn't work.. But I will make sure all connections are soldered as well as the motor to the esc. Thanks for the help
Old 01-12-2014, 09:55 PM
Oztruck wrote out this detailed post of how he does the mix on his radio, I think it's the same one you're talking about.
http://www.scale4x4rc.org/forums/sho...t=76143&page=2
Old 01-14-2014, 08:44 PM
^^^^^^^this^^^^^^^^
Old 01-14-2014, 08:56 PM
thank you everyone for the help, much appreciated. i just got the proper specs on the mixes for the turnigy so im going to see if that's where i made the mistake and just go from there. hopefully it works
Old 01-15-2014, 07:29 PM
Well I got it to work. Had to reset the mixes and do it all over again. So now I gotta fill the hydraulic fluid and get to work. Thanks again for the help everyone
