Old 01-19-2014, 12:08 PM
cabs cabs is offline
Default my new ride
Well guys I just finished with some of your help. My last issue is a driveshaft. I used rics 3"extensions and need a driveshaft approx 230mm. Can anyone lead me to one or do I somehow need to use 2 driveshafts and a carrier bearing.
Thanks guys, looking foward to gettin her going
Old 01-19-2014, 12:16 PM
Brian in PA's Avatar
I'd rather be truckin'
Default Re: my new ride
Search the forum. Tamiya cowboy did a nice write up on how to custom biuld one.
Old 01-19-2014, 02:01 PM
Lmackattack's Avatar
I have not seen an aftermarket driveshaft that looks real and is longer than what rc4wd sells. On both my king hauler frames I had to use a carrier bearing and 2 drive shafts...
But of your staying prototypical...real trucks of that length will also have carrier bearings and 2 driveshafts..
Old 01-19-2014, 02:21 PM
Thats what i thought, thanks guys
Old 01-19-2014, 05:26 PM
thebat's Avatar
thebat thebat is offline
that trucks sweet man i can't wait to get my built.
Old 01-19-2014, 07:01 PM
Mikeo78's Avatar
Mikeo78 Mikeo78 is offline
Mikeo78 is on a distinguished road
Looks good buddy! 👍
Old 01-19-2014, 08:41 PM
Thanks guys, Got er almost done with some awesome parts from Russ-true scale rc, Steve at ihb and Ric at garden trucking and will be adding a cool bow tie visor from Rod. Just have to find a carrier bearing and some drive shafts and its good. Was going to add the lift axle but I kinda like it like this. I was no good at drilling rails so I used the extensions.
Old 01-19-2014, 09:02 PM
Here is an under shot
Old 01-19-2014, 09:12 PM
I have seen different styles of mountine options for center support bearings.
Some are the same width as the tamiya frame others are skinny and will need to be bolted to a plate and the plate bolted to the frame.
Rc4wd has a few styles that I have used with good results. They now have a nice skinny one that looks like it bolts to the frame.
http://store.rc4wd.com/Transfer-Case_c_24.html
Old 01-19-2014, 09:25 PM
Thanks for the link mack attack
