Old 01-22-2014, 11:45 PM
der82c der82c is offline
der82c is on a distinguished road
Default 1/14 Komatsu PC200 build
Hi guys,
I am Derrick, friend of Izzul. Previously, together we built the "1/10 Komatsu PC650" and were posted on this forum at:
http://www.rctruckandconstruction.co...VATOR+MALAYSIA
the cost to built the 1/10 is expensive and to travel the huge excavator is killing. some of the local rc fans had requested a smaller, budget-able and less-power version, the "1/14 Komatsu PC200"
And the story goes on again...
Old 01-22-2014, 11:48 PM
start of with a small cute die-cast for the critical dimension and feature.
Old 01-22-2014, 11:51 PM
then every night on screen for CAD drawing...
Old 01-23-2014, 12:01 AM
and many more nights...
Old 01-23-2014, 12:07 AM
Default Re: 1/14 Komatsu PC200 build
MOre and MOre sleepless nights...
Old 01-23-2014, 03:38 AM
Not to forget those standard parts
ooh, but the control valve is not from standard part, its custom made
Old 01-23-2014, 03:52 AM
the fabrication of sheet metal
Old 01-23-2014, 04:04 AM
mild steel arm and boom, sus bucket
Old 01-23-2014, 04:13 AM
Great idea putting the swing motor in the cab area, all too often a wasted area by other model companies.
Steel fabrication is becoming more popular all the time & so much simpler to form & weld than aluminum... not to mention the weight advantage that these models are always lacking.
The last pic of the press, is it a place where you work daily? Are you a metal worker by trade?
Old 01-23-2014, 10:47 AM
the swing motor, i intend to put it vertically instead of horizontal cause its a PC200 body, its relatively small size excavator. not much space left, cabin area is the only chance.
aluminum is light weight but don't have the strength, need up to thickness 3mm to nearly equal the strength of 1m steel. while my welder always quit worry on welding aluminum, tricky skill needed. while steel is less costly, but the rusting problem. epoxy powder coat will solve it.
i am a CAD drafter in a sheet metal fabrication factory. so it was easy for me to done all those metal stuff. i do the drawing, while my guy do all the bending, welding, drilling and etc. they are experience and skillful worker, but sometimes they got me boil up my head when they create rejected parts.
Old 01-23-2014, 02:28 PM
Very nice job. I really like the size of your excavator and the power. Ed
Old 01-24-2014, 12:55 AM
I'm interested to see how your custom valves turnout!
Cheers, Neil.
Old 01-24-2014, 04:15 AM
Cheers, Neil.
hi Neil,
look familiar, isn't? No, is not the one you think. still it is a same old spool-valve but internally i redesign the whole thing for better seal to prevent over-flowing, improving the fluid route and adapt for bigger size connector and hose. ease of attaching extra flange if needed
Old 01-24-2014, 06:50 AM
Yes, looks very familiar ... so what size ID hose will you be using?
Old 01-24-2014, 11:35 AM
for this model will be using ID 2mm dia. hose. in the future, for bigger model will try for ID 4mm dia.
i won't stop, will push those pumps and valve to the limit. oooh yeah!!!
Old 01-24-2014, 11:42 AM
ready to send for epoxy powder coat.
3 sets, as per request will be a black and white excavator. what?!
notice that, don't have any cabin cover parts in the pic, more story coming in.
Old 01-24-2014, 11:57 AM
it's my first 3d-print out experience. it took me 7hrs just for waiting on this front-cabin cover done printed out. i still have to do the rear counter-weight cover and engine cover. how many long hours it is going take anymore?
No, i put aside this 3d-print for awhile, i need to install those metal parts now and have the system running, on priority.
Old 01-25-2014, 04:36 AM
Very nice work!
Old 01-25-2014, 10:27 AM
got those sheet metal parts back from powder coat
so does partial of those machining parts. while my factory will have the tools and machine to do all those sheet metal but do not have the facilities to machine these parts. luckily i can always get help from next door. the cnc machining workshop is just next to my work place.
i lay out all the parts i got today, it's look like a complete set but no, still some critical parts the machining shop owe me.
oh well, chinese new year is just few days away. all works at metal shop is shutting down. i need to get prepare for the festive. i think i will just put on-hold for 10 days holiday.
Old 01-25-2014, 10:36 AM
Originally Posted by thuangs View Post
Derrick, very nice work! Thanks for sharing. With experience on 650, this one is even better. Looking forward to seeing this in action.
Wishing you a very happy CNY!
Kevin
hey Kevin!
how are you? how is the progress of your excavator?
it will be slightly ease for me on this model since all the pain i got from the PC650. tell you a secret, we nearly gave up that time, problem keep occur one by one, sleepless night thinking of solution. lack of experience. but still there a challenge for this model as it's a PC200 which i had to squeeze in all the system in to its small compartment.
how about this way, Kevin. i try my best to finish this a.s.a.p in order to bring this model to SG, to play along with yours. how is that? by that time you must too able to finish yours , ok?
Happy Chinese New Year! to you too. wishing you have a prosperous yearS
