Old 02-20-2014, 02:16 PM
motocrawler motocrawler is offline
motocrawler is on a distinguished road
Default Limit switch wiring help
I just finished converting a Joskin tilt trailer, I am using a screw type lift mechanism and want to add limit switches on each end. I am using a speed controller to control the motor direction and using a 6V pololu geared motor. My question is I am not sure how to wire the limit switches in to the system/circuit. I am also horrible at reading electronic circuit schematics so please be easy on me. Any help would be appreciated. Thanks!
Old 02-20-2014, 02:36 PM
kaptain Jack's Avatar
Default Re: Limit switch wiring help
Here you go, M stands for motor
Old 02-20-2014, 03:04 PM
Thanks for the quick response, but I can't see the first photo/picture (it says the user removed the photo), in your second photo it looks like you placed a diode between the terminals C and NC, is that mandatory or can I get away with not having a Diode?
Old 02-20-2014, 04:30 PM
Diode serves as a gate allowing the flow in one direction, it's a must!!
Old 02-20-2014, 04:53 PM
Yes, diodes required to make it work. Also have to be installed in the proper direction. You can see a silver band on one end of the diode. The wire on that end will not allow power to flow that way.
Here's a video I made just a few months ago. It may help to explain.
http://youtu.be/XqReoXCzzw0
Mario
Old 02-20-2014, 05:19 PM
Thanks so much for the info, I guess I need to get a diode now. As far as actually wiring the switches what wire goes where, etc?
Old 02-20-2014, 06:38 PM
heres a quick drawing. Nothing as nice as the drawings Nathan makes but... I didn't use the diode symbol from a schematic and just drew it as what your looking at when you get some.
Mario.
Old 02-20-2014, 06:52 PM
Hey that's better than the drawings you were sending me months ago!
Old 02-20-2014, 07:06 PM
Lmackattack's Avatar
Great info guys....!! . I too was wondering how to do this also...So basicly we need
2 normally closed limit switch
2 diodes
Motor
Esc
That's very simple to wire up...
Wires to connect everything...
Old 02-20-2014, 07:25 PM
Just one other thing to consider is,
You need to use switches and diodes that can handle the amperage required to run the circuit. I'm not sure what size motor and drive you are using.
My dump truck switches and diodes are rated for 1 amp. I have yet to test the box with a full heavy load and see if it blows a diode or switch. If it does, I'll try a 2 amp version.
Old 02-20-2014, 07:51 PM
I was surfing eBay and see a lot of people list these micro switches as no/nc
Does it specifically have to be a nc switch or is it just hiw it's wired will determine the nc position?
Old 02-20-2014, 08:09 PM
Some switches have 3 terminals and you can choose NC or NO.
a NC switch is what keeps this circuit simple. Using a NO switch would require more diode fun that you don't need.
Normally closed as to say there is a connection when not touched. when you push on it, power is lost.
heres a switch with choice of no/nc
http://www.robotshop.com/en/micro-co...it-switch.html
Old 02-20-2014, 08:18 PM
Do a search for them on Amazon. I bought some from there that were pretty reasonable if you don't need them in a hurry. They came directly from Hong Kong...
Old 02-21-2014, 02:18 AM
Thanks so much for the drawing supermario it explains everything so simply and clearly! I am using a 7.2volt lipo battery and it is powering a Pololu 25D 99:1 gear motor. What amperage switch would you recommend and what diode? Thanks again!
Old 02-21-2014, 04:51 AM
Those are the same motors that I am using on my dump boxes. I am running 5amp switches because that's what the motors stall current is.
Old 02-21-2014, 11:51 AM
dmess62's Avatar
dmess62 dmess62 is offline
Mario, so do you just solder connectors on the ends of wire to plug in to esc or does it run off a seperate channel. And correct me here but this esc is not the main one you run the truck off of. You need seperate one.
If so how do you connect the dump esc to main esc
Dave
Old 02-21-2014, 12:55 PM
Hey Dave. Your right, you need a separate ESC to run the box function. I found a cheap china one on ebay for 10 bucks. 10 amp I think.
Use whatever style connector you prefer to hook up to the ESC .
I connect that ESC to the radio channel for right stick up down or elevator.
The only connection between the main ESC ( drive for the truck) and the one for the box is main power supply from the battery. I soldered both power wires together and installed a battery style plug to fit the ones I use .
There is another option rather than using a ESC. Raising and lowering a box can be a on or off type function. You could use a relay of some sort and trigger with a toggle switch or something from the radio.
I'm just learning about stuff like pico switches and it was just easier and quicker for me to use the horn and fifth wheel function seeing as a dump truck has no fifth and I don't care about the horn. Using the ESC I can raise the box full speed or just a little or anything in between.
It's all about personal preference and space available, cash flow. That's another thing that makes all our builds so unique. So many ways to do a variety of things.
Mario
Old 02-21-2014, 03:04 PM
A terminal block is a better way to go to connect your electrical devices to main power supply... sure beats having to cut & resolder everything when one device sh!ts the bed.
http://www.thesource.ca/estore/Produ...FY1AMgodRFwADw
Old 02-21-2014, 05:00 PM
I totally forgot about checking The Source online! I go to the local one and they got nothing !
Thanks for the link Joe, I agree junction block is the way to go I just wondered where to get. I'll keep the cash in Canada and order from the source
Mario
Old 02-21-2014, 10:17 PM
There isn't much we can order from our own country for our hobby, is there Mario?
