Old 03-08-2014, 09:19 AM
Dans34 Dans34 is offline
Dans34 is on a distinguished road
Default 1/14 parts on a 1/16 bruder cab ?
i got a bruder/scania cab from ebay and its 1/16 scale , looking on ebay all i can find are 1/14 parts (axles , springs etc)
can i use the 1/14 parts on my build without them looking out of place or not fitting ?
Axle in question : http://www.ebay.co.uk/itm/200983451885
Springs : http://www.ebay.co.uk/itm/201021234225
Old 03-08-2014, 09:26 AM
Lmackattack's Avatar
Default Re: 1/14 parts on a 1/16 bruder cab ?
A lot of people use the bruder cab on tamiya frames. The tamiya axel is a little wider and the wheels will stick out a little... You can use a tamiya acel but you may have to modify the wheel off set to get the wheels placed correctly....search YouTube for bruder r/c and you will see some builds. lots of people have modified the bruder Mack into a tamiya frame. I'm sure you could do the same with the scania...
Old 03-08-2014, 09:32 AM
thanks , if its just a case of some small adjustment then it wont matter so much
Old 03-08-2014, 10:30 AM
Actually I retract my previous statement.. I just measured my stock bruder mack and stock tamiya widths at the wheels and they are both about the same overall width. The bruder was 7-1/4" the tamiya was 7-1/8"
