Old 11-08-2010, 09:56 PM
pumptech's Avatar
pumptech pumptech is offline
Default bruder trackloader conversion
Hi all
I have this thread over at scale 4x4 thought I would post it here.
Converted the Bruder trackloader and added a set of forks.
Used auger bit method to simulate hydraulics.
A few pics and video.
http://www.youtube.com/watch?v=ley1w..._order&list=UL
Old 11-08-2010, 10:00 PM
pumptech's Avatar
Default Re: bruder trackloader conversion
Few more pics
Old 11-09-2010, 09:17 AM
Very nicely done! I like that the auger-drives provide operational speeds consistant with the real thing. Haven't looked at the build at Scale, but do you have parts list for the servos used for auger-drives?
Old 11-09-2010, 10:21 AM
dirtpusher9's Avatar
Moderator
Great work. The augers really do the trick.
Old 11-09-2010, 04:48 PM
pumptech's Avatar
Hey guys thanks for the comments.
Hey Sparkycuda ,Parts list for the rams.
I"ve been looking at some other ways to connect the rams to the servos,
the method that I show in the pics above (first post) seemed to work ok for a while then it started slipping a little under strain.
Come up with this method and it seems to work much better.Weld the bit to a short piece of SST tubing.
Parts needed
3/8" SST tubing with 1/4" ID (seems to work the best)
1/4" wood auger bit or masonary bit ( much cheaper)
I used # 4 drill bit ,#4 tap ,#4 set screw ( If you can find bit ,tap,set screw smaller that would work to)
Pic to follow on my ram
Old 11-14-2010, 01:41 PM
pumptech's Avatar
Hi all
Took a revisit on the rams. Tried a piece of 1/2" SST tubing and the 3/8 " slides perfect in it.Able to hide the auger bit.I 'm thinking it looks a little better.
Had to cut out a portion of the sides,the 1/2" sst was rubbing and sticking .There is a lip that sticks out on the side of the model.Need to mask it again and paint the rest of the side,did not blend as well as I thought.
Make a floorboard for the cab(had to cut out ,room for battery) hide the wires and that should pretty well do it.
Old 12-15-2010, 12:45 AM
kamyoncu's Avatar
kamyoncu kamyoncu is offline
kamyoncu is on a distinguished road
I will convert mine to hydrolic. Is it posibble to add scrapping steps of the loader ?
CAT: 963 B Scaleart // 345D LME Wedico // CS 563 E Handmade
Mercedes Benz: SK 3544 AK 8x8 Premacon // NG 2636 AK 6x6 Wedico Handmade
MAN TGS 26.500 6X6 Wedico - Premacon
MACK Granite 8x6
Old 12-15-2010, 07:45 AM
The rams look great. Very nice work.
Old 12-15-2010, 08:34 AM
pumptech's Avatar
Thanks Smallhaul
Old 12-15-2010, 08:33 AM
pumptech's Avatar
Hey Kamyoncu
Not sure what you mean by (scrapping steps) , more build pics mabey
Old 12-15-2010, 10:48 AM
kamyoncu's Avatar
Originally Posted by pumptech View Post
Hey Kamyoncu
Sorry for my english, I tryed to mention separation steps of the bruder loader. I wonder it.
MACK Granite 8x6
Old 12-15-2010, 01:26 PM
pumptech's Avatar
Well,there's not really a seperation step by step.
It's been awhile since I took it apart.
I removed tracks,front rollers,used small flat head screwdriver for the tabs,front portion of the model slips out the front with boom,bucket.Once the front portion is removed ,the cab pops off.Removed sides (guard on the sides)(w/rollers)Takes a little force to pull the sprockets off of the axles.Thats pretty much it for taking the model apart.
Hope this helps.
Tommy
Old 12-15-2010, 08:27 PM
kamyoncu's Avatar
I hope that it is works thanks a lot for your help
MACK Granite 8x6
Old 04-23-2011, 08:16 PM
pumptech's Avatar
Made a video of the trackloader moving some sand.The sand works good after I wet it down a little.
http://www.youtube.com/watch?v=PCGiv...el_video_title
Old 04-24-2011, 12:27 AM
rockNmayhem's Avatar
Sweet little vid you made. Looks like it does pretty well for the size and weight. Before long you're gonna have the whole Bruder fleet opperation going ain't ya?
~Tyler~
RockSolidCustoms
Old 04-24-2011, 09:10 AM
pumptech's Avatar
Hey thanks Tyler
Yea it does pretty good considering its a Bruder,lol
Old 05-07-2011, 10:05 AM
TheMachinist's Avatar
Are yout using a Tamiya dual motor gear box for track drives? The loader seems to have good power and it works really well in the videos.
Old 05-18-2011, 01:33 PM
pumptech's Avatar
Sorry so long to respond
I'm using these motors http://www.robotmarketplace.com/products/0-GM14A.html
Then using hacked servos for ESC's
Old 06-27-2011, 08:29 AM
pumptech's Avatar
Another vid of the trackloader,lol
nothing like some fresh dirt,lol
loading some future projects one of these days....
http://www.youtube.com/watch?v=2yTWK...el_video_title
Old 05-08-2011, 12:53 AM
Pumptech, Great looking build as usual. I do have a question for you though. Are you getting any wear on the pivot points of the boom or bucket on any of the bruder models you have converted?
