Old 03-22-2014, 06:58 PM
wolfws6's Avatar
wolfws6 wolfws6 is offline
Question Kenworth sleeper window trim????
Need some suggestions on how and what to use for the trim around the sleeper windows. Someone on this forum had a solution, but I cant find it. Some trucks its black or chrome. I need contrast between the window and the body like the real trucks. I think if just slap some clear window alone it wont look right. Any thoughts and suggestions welcome. Thank you
Old 03-22-2014, 07:28 PM
Lmackattack's Avatar
Default Re: Kenworth sleeper window trim????
just thinking that you might look for some thin plastic C channel and a little help with some heat to get it to bend around the corners. if your real keen on a rubber look I have seen some people cut the rubber back from a thread of thin wire and pull the copper out. then they push the rubber over the plastic edge. kinda like how the real gasket works.
that's my thoughts...
Old 03-24-2014, 10:22 AM
I have some H-channel rubber used for windows. It is a product of http://www.knupfershop.de/, called Gummi-H-Profil, 4mm and 2.5mm sizes. Purchased in US through http://modelmotorcars.com/ and it is just like the channel used on real vehicles and heavy equipment.
Old 03-24-2014, 08:26 PM
wolfws6's Avatar
Awsome, thank you so much fellows!!!!
Old 04-11-2014, 01:50 AM
Ive used the wire idea with 1/25 models before. it does work. Just gota think outside of the box and see what you got laying around everywhere.
