Old 04-09-2014, 08:49 AM
buzzy16 buzzy16 is offline
Default Sabertooth 2x12 RC problem
Hi, I have a problem with the sabertooth 2x12 RC that's in my dunp truck, I have the drive motor on he motor 2 on the sabertooth and the motor for the screwdrive is on motor 1, everything works fine apart from the screwdrive only down at a fraction of the speed as going up. I have tried changing the travel and the trim on my controller but it doesn't change anything. I have the motor on the 3 pos switch on my dx8.
I was hoping someone would be able to help me.
thank, you i advance.
buzzy
Old 04-09-2014, 11:23 PM
trucker n's Avatar
Default Re: Sabertooth 2x12 RC problem
So are your EPA the same on the 3pos switch u might want to look at your manual for the radio
Old 04-13-2014, 02:41 AM
Originally Posted by lostinoz View Post
Hi Buzzy.
Get in touch with dimension engineering direct, They are good to deal with any problems you are having, they helped me out.
http://www.dimensionengineering.com/
Regards Ralph P.S. Do you ever get over to Victoria ?
Thanks guys, I fixed the problem, turns out I had to have one of the switches down for it to find neutral.
And not really Ralph, I really should there are a few of you guys popping up in Victoria and even WA, it's a shame there's no one around my area.
