Old 04-21-2014, 04:39 PM
calum_scania's Avatar
Default Liebherr 922
Hello people this is my new machine out for some digging yesterday
Old 04-21-2014, 04:42 PM
Default Re: Liebherr 922
Can we see a video of it working
Old 04-21-2014, 04:44 PM
pumptech's Avatar
pumptech pumptech is offline
nice pics ,she's a digging
Old 04-21-2014, 04:53 PM
Nice pictures
Old 04-21-2014, 08:44 PM
headers headers is offline
Very nice just love seeing these machines working in some good old dirt and such
Old 04-22-2014, 01:16 PM
avel avel is offline
Hello! new member. Nice machine!
Old 04-22-2014, 05:03 PM
Thank you guys!
This is my first hydraulic machine, i'm slowly ordering up new parts to improve the way it performs and looks
Can anyone advise on my hydraulic pump? I'm looking to upgrade it to speed the movements up..
Old 04-23-2014, 02:38 PM
MoRockN's Avatar
MoRockN MoRockN is offline
Originally Posted by calum_scania View Post
Thank you guys!
If you wanna keep the same pump, you can change it to brushless motor from Leimbach and that will make it more smooth. You also can up the bars ( or psi ) on the pump and that will make it seem faster ( I think 18bar is max ), but that also puts tons of wear on the components. If you want a new pump you can use a JUNG setup if you can find one, only thing is you have to change the layout and I'm not sure you can fit all of it on there. I have the same pump on my 944 and it's awesome. There are more powerful pumps out there but only fit larger machines with more space.
Old 04-23-2014, 04:36 PM
Currently in the process of buying a Martin Kampfshoff pump which i believe has a jung motor fitted.
If it wears out the cylinders or valves i will just upgrade them to better spec items
I am also looking for a pressure gauge and fittings in the UK?
Calum
Old 04-22-2014, 05:21 PM
My friend said use the same pump from leimbach and order extra rubber couplings with the pump
Old 04-23-2014, 04:38 PM
Hey Ross u will not find a pressure gauge and fittings in the uk especially where you live ?
Old 04-24-2014, 02:55 AM
Judging from the pics, this looks like an old machine... early 2000's?
It probably has 1.5mm ID hose & fittings...
Just to go to 2mm ID plumbing speeds up the hydraulic flow dramatically with your current fitted Leimbach pump... similar to this one.
http://youtu.be/yNMtwIds6Vc
Old 04-25-2014, 05:34 PM
The age of the machine I am unsure of? As it was second hand to me..
I did think about changing the hose size too, but I was unsure if it make that much difference? It was horribly slow before, so I changed the pressure on the pump which has made it better now.
I decided to change the pump as the Leimbach would be working too hard all the time to keep everything moving. The machine works very well, the electronics will be replaced and modified as the pump runs continuously and the track control takes up a huge amount of space
Calum
Old 05-20-2014, 08:32 AM
Nice 922 Calum_scania i like that machine because of its size.
Joe, the thread size on the 1.5mm id and 2mm id fittings are the same? What is a good source for the 2mm id fittings? Thanks.
Old 04-27-2014, 04:43 PM
Out again for some more digging in a new location
Then the driver had a quick tea break
Old 04-27-2014, 06:22 PM
Nice picture quality
Last edited by thercfreak2012; 04-27-2014 at 06:24 PM. Reason: needed to change something
Old 05-19-2014, 04:54 PM
Can anybody tell me where I can get a replacement motor for my drive?
Old 05-19-2014, 05:42 PM
Check the leimbach website
Jake
Old 05-20-2014, 12:37 AM
http://www.der-getriebedoktor.de/sho...ahlproseite=20
Old 05-20-2014, 10:07 AM
I don't believe so Scott. A great source is the link that avel posted above, they speak great English & ship fast to North America.
If you look at the pages in Hydraulic -> Leimbach -> Spare Parts on pg 1 & 2, you'll see the difference in thread size vs straight nipple/hose size... it varies again when using a 90* fitting.
http://www.der-getriebedoktor.de/sho...l.php?kid=3121
http://www.der-getriebedoktor.de/sho...&von=21&bis=40
