Old 04-22-2014, 05:24 PM
cosworth34677's Avatar
Default how would i do it?
how would i go about making a hydrualic motor for a small winch?
something simple if that possible! that my challenge to you guy!! plenty of pictures if you can
Old 04-27-2014, 02:06 PM
Default Re: how would i do it?
I think you would be far better off using an electric gearhead motor, or even a servo winch. A hydraulic motor is something you aren't going to be able to build very easily. An electric gearhead motor would most likely have greater torque too.
Old 04-27-2014, 02:08 PM
ya that what i did . easier doesn't look scale but works great
Old 04-27-2014, 09:29 PM
Backlash Backlash is offline
Could you make a scale, non-functioning winch from Styrene, and then place the working non scale winch (eg servo or 3 racing winch) behind or below, with the wire or rope going the non functioning unit to give the illusion that it works?
Old 05-04-2014, 08:10 PM
Take note - a hydraulic motor is a gear pump. So get a gear pump and hook it up!
Old 05-04-2014, 08:21 PM
i was thinking something kind of like a waterwheel? machining a whole putting a gear in the whole and somehow pumping fluid around the gear. if that made since
