Old 05-24-2014, 06:46 PM
Blender's Avatar
Blender Blender is offline
Default how do you organize your model's electrical?
For the models which require several electrical devices (drive esc, external bec, alternate esc, light module, etc.) how do you go about connecting all theses to the single on board battery. Organization, compact size and serviceability are important to me. Trying to squeeze all of those wires onto a single deans plug never works out for me. I'm left with a huge tangle of wires which is hard to service and will likely fail at the poorly soldered joint.
In the 1:1 world we always use fuse panels to protect the wire when it steps down in size. The RC world has never been into such a thing, so ultra mini fuse blocks are not available. I've never heard of anyone using a chassis ground in RC.
How do you guys approach this situation? Please share pictures/diagrams/stories, etc.
This is the best I could come up with so far:
A female plug for each device is wired in parallel with a main cable run. Each electrical joint would be pretty easy to wire and swapping out parts would be easy without soldering. I suppose the plugs/wire used would depend on the actual current, but for low current things the minis might be ok.
Old 05-24-2014, 09:21 PM
Default Re: how do you organize your model's electrical?
I know what you mean. my day cab wiring was a challenge. I got this pic of something I think might work for you, space permitting. Sad part is..... I cant remember where I got it!. I think it was from PMD????
Old 05-25-2014, 11:19 AM
Blender's Avatar
That looks great. Do you know the ballpark dimensions?
Anybody try a negative ground system? Squeezing in only one of these terminals wouldn't be too bad.
Old 05-27-2014, 04:44 PM
So they are from PMD . I guess my memory ain't so bad after all
http://www.gardentrucking.com/list.t...minal%20Blocks
Each terminal looks like the 5mm width size so probably close to 4cm long or just over an inch long....?? Send them an E and ask for dimensions. They are great people to work with.
No frame ground is just another challenge and thing to deal with when building. All part of the fun.
Mario
Old 06-22-2014, 01:35 AM
thebat's Avatar
thebat thebat is offline
mario that looks like it is form the place you got the leds from that you provided a link to m of i will find it and post it here
Zach The Bat Flowe
Keep On Rollin.
