Old 11-18-2010, 07:45 AM
td9clyde td9clyde is offline
Dozer Builder
Default broken bits
how do or can i get a 3/32 drill bit out that is broken off down in the hole?
Old 11-18-2010, 08:09 AM
dirtpusher9's Avatar
Moderator
Default Re: broken bits
If it isn't to far down in the hole I take something, sometimes my scribe, and drive it down into the bit and break it up. It usally works.
Old 11-18-2010, 09:01 AM
Can you drill another hole from the other side. The bit will push the broken one out if done carefully.
Old 11-18-2010, 10:48 AM
what kind of metal is the hole in
if it is alumium you can use acid to dissolve the tap or drill bit
Old 11-18-2010, 12:17 PM
this is a good 1 to try all the hubs I have sitting in the scrap with a broken tap in them
Old 11-18-2010, 11:44 AM
pugs pugs is offline
Drill bits should be fairly easy to get out (taps are a biotch). Like was said try and poke at it with something or possibly even turn the piece upside down and bang it against the bench to get it to fall out.
Jeff
Old 11-18-2010, 01:09 PM
Dozer Builder
carbide bit in hot roll steel about 3/16 ths down in the hole can't drill from the other side i am afraid i might break something else off in it it's the roller bolt holes i hate to trash a whole side frame lol
Old 11-18-2010, 01:33 PM
don't trash it for a broken bit . just work at it you should be able to get it out . I know it's frustrating as all heck . heat it if you have to , to expand the steel and bang it upside down on something . If your careful , you can drill from the other side enough to push it out . I've only been trashing my aluminum hubs with broken taps
Old 11-18-2010, 02:14 PM
Bodyman Bodyman is offline
Bodyman is on a distinguished road
ihbuilder,
they make a tap removal tool. i have one. its has 3 prongs with a band
and it slides in the section of the tap that doesnt have any cutting bits.
steve
Old 11-18-2010, 02:18 PM
If you had a broken tap or drill in an aluminum part (or brass or other non steel) you can use Alum, aluminum sulfate (dissolved in water) to dissolve the steel and not the aluminum, it's slow going. Nitric acid works faster but is not always easy to come by.
If you have taps or drills that are plugged up with aluminum you can use Red Devil Lye (dissolved in water) to dissolve the aluminum and not harm the tap.
Jeff
Old 11-18-2010, 04:01 PM
Originally Posted by Bodyman View Post
ihbuilder,
steve
I didn't know if they work for 2-56 or smaller
thanks Jeff this is very useful
Old 11-18-2010, 02:30 PM
Being a carbide bit in a steel part I would go with heating the part up. The steel should expand alot more than the carbide, and hopefully then a good whack upside down on a benchtop will send the bit falling out.
Jeff
Old 11-18-2010, 04:32 PM
So what kind of lubrication are you guys using while drilling or tapping?
Local machinist gave me a blue colored liquid (forgot what it was called) that worked great, till I ran out of it. Now I'm using Sulflo cutting oil, which is alright for aluminum cutting/threading, but the blue liquid worked much better.
Old 11-18-2010, 05:51 PM
Joe ' I use WD 40 , it works well . The reason I brake taps is the same reason I can't take good pics when holding the cam. . I found ATF works great on alum. when turning on the lathe , just gets a little pricey if you have to buy it just for that . Being a self taught machinist I've never herd of the different typs of lubes to use with what metals
Steve
Old 11-18-2010, 05:59 PM
calm n sedated calm n sedated is offline
calm n sedated is on a distinguished road
Clyde, is it full carbide or just carbide tip? If it's a tip and the shaft is hss, grind it or bore a flat surface on the fractured end. Next tap it or just drill a smaller diameter hole with a full carbide bit and lubrication. Now back it out with an extractor. Worse comes to worse you may have enough space to spot weld a rod to the flattend end of the bit or the hole that you drilled into the fractured bit and crank it out.
Old 11-18-2010, 06:20 PM
Iron Art's Avatar
Iron Art Iron Art is offline
Clyde, As a last resort, befor starting over, if its one of the verticle holes in the track frame, take a cutoff wheel or grinder and excavate it out, could use a burr, weld up the damage and grind the area smooth or set it up in your mill and finish the repair, redrill and retap. Steel and small taps are not real easy to work with. Fred
Old 11-18-2010, 06:42 PM
since it is carbide in steel heat the hec out of the steel and the bit till they are both red hot and hit the bit with a punch and hammer the bit should break up and turn mostly to dust carbide becomes real britle when it is heated. I learned this trick from an older gentlman at work.
Old 11-18-2010, 07:34 PM
Dozer Builder
thank you all for the great quick responses i picked up a new drill bit and drilled the side and dug it out it was stuck pretty good in there took a lil bit to get it to even move around but when it came loose i got it pushed up and pulled it the rest of the way out with needle nose pliers and yes it is very frusterating when that happens but i kept drilling the rest of the holes and when i got them done i drilled on it and worked it out
Old 11-19-2010, 08:44 AM
here are a few posts from the anodizing group about broken taps
i hope this helps
my tanks are not set up yet or i would try it and see
I've read that a steel tap that's broken off in a part will dissolve away during
the anodizing process. One of the larger parts I need to anodize does in fact
have a broken 4-40 tap stuck in it, but I don't want to contaminate the
anodizing bath. Can the tap be dissolved just by soaking the part in non-diluted
battery acid? Or is the electrical process of anodizing necessary in order to do
this in a reasonable amount of time?
Re: [anodizing101] Re: Dissolving a Broken Tap
..I have also used the nitric acid to dissolve thread forming taps from aluminum. The stuff I used was a kit called 'Tap-Out' sold in machine tool shops...it had the acid, some clay to build a 'dam' around the top of hole, and some pieces of stainless steel wire, used to agitate the acid every few minutes..
The acid is a mixture of Nitric acid and alcohol...called nitol...it's only about 20-30% acid. You can buy nitric acid at a laboratory chemical store, but it will be a solution of nitol...nitric aid is very corrosive....even at the 20-30%...and cannot be mixed with water as a storage ...
I don't know the why of how it works, but doesn't attack the aluminum to any degree.
Nitol is very slow to dissolve tool steel, which is why it's not usedin machine shops in lieu of EDM....and hole must be sealed at the bottom of course for nitol.
Jack,
I have anodized a bunch of taps out. I have never tried it with just acid. What I would suggest is to setup as small a tank as you can to get the tap out and keep that acid separate from your anodizing bath.
Regards, Ray
Old 11-19-2010, 08:47 AM
sorry just saw that the tap was in steel
thats what i get for not reaDING EACH POST UNTILL THE END OF THE THREAD LOL
