Old 11-18-2010, 08:08 PM
woodhog's Avatar
woodhog woodhog is offline
Smile 3 speeds
what are most new builds usin . im plannin on building a ground up truck what should i use r2 or somin else
Old 11-19-2010, 03:37 PM
Default Re: 3 speeds
There are a lot more options these days then in the past, if you are okay with less then 3 gears. The best way to decide what will work the best is to consider the type of truck you want to build, and then consider what you want to spend. If you are tight on space, an R2 would work well. Axial transmissions from the rock crawler trucks work nice too. Or search for a compact planetary gearbox, or gearmotor. There are also the Tamiya 3 speeds, Wedico 3 speeds, Scale Art 3 speeds, and some have used the Traxxas E-Maxx transmissions as well. Just about any of these would work well and be pretty much bullet proof.
Old 11-19-2010, 04:49 PM
aseejr aseejr is offline
I just ordered one of these to try out:
http://store.rc4wd.com/3-Speed-Full-...ack_p_830.html
They also have a few other interesting pieces.
Old 11-19-2010, 06:21 PM
woodhog's Avatar
thanks guys i have 4 crawlers might need a donation from one thanks for info
Old 11-20-2010, 07:40 PM
calm n sedated calm n sedated is offline
calm n sedated is on a distinguished road
aseejr,
my advice would be....get one strong servo (200 in oz or stronger), make sure its digital cause that rc4wd 3 speed tranny is real hard to shift.
Old 11-20-2010, 07:58 PM
Originally Posted by calm n sedated View Post
aseejr,
I have one of those trans in my black dump truck and he is right they are a pain to shift I am using a hitec 645MG to shift it. If it wasn't for getting it in a trade I wouldn't have it. A tamiya three speed with an AXIAL trans connected to it for a transfer case is cheaper and just as good in my opinion.
Old 11-21-2010, 08:36 AM
Semi Joe
Guest
Posts: n/a
i make the standard tractor 3 speed into a 4x4 tranny
i put full bearings in them too
http://cgi.ebay.com/ws/eBayISAPI.dll...e=STRK:MESE:IT
Old 11-21-2010, 10:46 AM
Bigrigger's Avatar
Joe, I'm curious. Does that mean all you have to do besides get your case is put in a drive axle and shafts? It does 6x6 right? Thanks
Old 11-21-2010, 11:21 AM
I have one of these it a 3 speed . Ed http://www.der-getriebedoktor.de/shop2/art31529.jpg
