Old 07-02-2014, 04:04 PM
MoRockN's Avatar
MoRockN MoRockN is offline
Default Weed killer/water Aeromax truck
Hi guys , been awhile since I built anything, but if you saw my Aeromax build thread, this is the plan from the get go and finally was able to execute the idea and start building this long awaited and MUCH needed truck . It's been almost 2 years since I planned this, shortened a flat bed trailer and the rest is all hand made. Thanks to my Buddy wolf for donating the Tank and helping out a ton with everything. Here she goes:
I wanted the bed to sit low like the real ones so some u stock was used
Now building the frame... But I wanted to use my wheel loader forks to pick up the whole thing and make it mobile. This is what we came up with
Joined two milled u shapes to make it big enough to fit the forks
Moved the pump to the back after seeing a real one with it just like that
First try at the hard lines... Fail..
How about a solid one without filter..much better
Sprayer mounts were a major pain in the rear to build.
And at last, my vision is complete, worked out great, simple and I can adjust the height and side position.
Scale hardware makes everything way more tasty....
That's it for now guys! I will do more work and post more pictures soon. Thanks for looking at my modest build. Comment , good or bad.
Old 07-02-2014, 04:16 PM
Default Re: Weed killer/water Aeromax truck
Sweet! Where did you get the little valves? Are you going to hook them up to a servo so that they can be adjusted or turned on and off?
Old 07-02-2014, 04:24 PM
MoRockN's Avatar
Thanks buddy! no servo, the real ones turn by hand so I'm sticking to that idea.... Cause it's less work . The little valves I found by accident at Menards. $1.97 . I wanted less complexity and more function.
Old 07-02-2014, 08:48 PM
Diesel Demond's Avatar
very cool love watching it all come together great build!!
Old 07-02-2014, 09:57 PM
low&slow low&slow is offline
low&slow is on a distinguished road
Yep, I want one for our local R/C Dirt Oval track!! That would be killer.
I'm subscribing to this thread
Old 07-02-2014, 10:23 PM
Dieselchopper's Avatar
Looking good!
Old 07-02-2014, 10:59 PM
MoRockN's Avatar
Thanks guys!! I got more done. Will post pix soon.
Old 07-03-2014, 02:12 AM
The Aeromax is a good choice for this inventive piece of equipment. I like your train of thought on this. Can't wait to see more.
Old 07-03-2014, 09:28 AM
Kaf343's Avatar
Kaf343 Kaf343 is offline
Cool idea, love it when you can incorporate work and play. Looking forward to more pics.
Old 07-03-2014, 10:18 PM
wow! I need to make something like this!
Old 07-04-2014, 02:00 AM
MoRockN's Avatar
Thanks guys!!! It's really turning out great. Here are more pictures.
Got the nozzles mounted and added some cross beams to the deck.
Now the splitter between the sprayers, had to be even to make sure it has even flow on both sides.
Some hard lines to hide the motor wires
This machine will have a filler access, bring another tanker or drive into a filling station ( coming soon) plug and fill. Mount made of brass as it needed to be strong cause it needs pressure to insure the filler nozzle is well seated . Let's get cracking
What's a water truck without a hose reel??
Wolf got the frame built while I made the riding rollers.
Simple you may think..... Took forever to get them just right and level. Everything in this build has easy removal/repair access. I hope to never need either option.
Added a diamond plate to the upper deck and some serious support as this tank will be heavy and the last thing I need is for it to break on the job site
Hard line mounts. Simple and easy
The hose will also be functional , I just don't have it plugged yet.
Let's shoot some paint on this piece shall we??
And last but not least
I tested everything and all works flawlessly !!! I changed out the stupid white tanks and side skirts for plain chrome tanks. Looks much more work truck like. Now the part I hate most, making LED's and fitting all the crap inside the cab. I will post a video soon after it's all done and driving under it's own power. Thanks guys for checking out my build. I hope this gives you some ideas if you were thinking of building one for whatever reason , my reason is the weeds are taking over my construction area and now they will be history .
Ayoub
Old 07-04-2014, 07:30 AM
cosworth34677's Avatar
geez very cool
Old 07-04-2014, 12:37 PM
MoRockN's Avatar
Thanks boss!
Old 07-04-2014, 01:19 PM
This a nice machine looking forward to the video! When you made the filler nozzle box how did you bend your brass, the bends are flawless.
Old 07-04-2014, 06:33 PM
MoRockN's Avatar
The bends were done by sliding the brass in a vice and bending it by hand. Worked perfectly.
Old 07-04-2014, 09:35 PM
Blender's Avatar
Blender Blender is offline
Great build. What holds the pump/tank frame to the flatbed? Magnets?
Old 07-04-2014, 11:44 PM
longhairRandy longhairRandy is offline
longhairRandy is on a distinguished road
This is a great build, cant wait to see it done.
Old 07-05-2014, 12:23 AM
MoRockN's Avatar
Thanks guys! Blender, the frame with the tank is sitting on it's own weight right now when it's full it will not move. But I'm putting straps on it soon for more realism.
Old 07-05-2014, 07:51 PM
NYHowie NYHowie is offline
NYHowie is on a distinguished road
Great idea and build, cant wait to see it in action.
Old 07-07-2014, 11:20 AM
rc_farmer's Avatar
Master Builder
Thats top-notch, great build.
Giving up is not an option!!!
