Old 07-08-2014, 05:53 PM
Question Truck puller motor W/ MFCU-01
I recently purchased an LRP Truck puller 3 motor @6000RPM from Ric at PMD. This motor has adjustable timing which is a first for me. Will this be ok to use with the MFCU-01? I think the manual says to use the stock Tamiya motor, and the timing thing, I don't know anything about so guys I'm at your mercy. Any help would be greatly appreciated.
Thanx, Big John
Old 07-08-2014, 09:16 PM
Default Re: Truck puller motor W/ MFCU-01
Leave the timing where it is at, it should be zero for equal fwd and rev power. Put it in and let it eat. You can go with a higher turn low rpm motor and you will be fine just don't go low turn with high rpm or you will cook the MFU.
Old 07-09-2014, 12:41 AM
Thank you so much Travis. Cooking the MFU would definitely be a bad day.
