Old 07-09-2014, 07:21 PM
rc_farmer's Avatar
Master Builder
Default Combine, JD Big Farm
Here is my steps to RC'ing a JD Big Farms combine
This is where the steering servo go:
Giving up is not an option!!!
Old 07-09-2014, 07:38 PM
Default Re: Combine, JD Big Farm
Looks like you are off to a running start, and a solid plan. Two questions, what scale is it, and is the head, ( I think that's what you call it) going to rotate?
Old 07-10-2014, 11:19 AM
rc_farmer's Avatar
Master Builder
Hey Jon, Ertl rates it as 1/16, but it is closer to 1/14. The header will raise and lower and the reel will rotate along with the auger. The unloading auger will swing out as well. This is the 3rd one I've done but first time taken step by step pics.
Old 07-10-2014, 12:24 PM
Can't wait to see more.
Old 07-10-2014, 04:54 PM
rc_farmer's Avatar
Master Builder
Here is a partial parts list as I go:
1.Ball bearings (3/16x5/16x1/8) 2 pcs
2. Motors: (2)
RC4WD z-E0051 @ 52 rpm @ 6v OR
Servocity 45-90 rpm micro motor
3. Motor: (1)
B104 micro gear motor (for drive system)
4. Vex robotic basic sprocket and chain set
5. 1/8" brass rod
6. 1/8" brass tube
7. Hitec 645 servos (2)
8. Styrene sheet .80 (1pc)
9. Drive Shaft (RC4WD) Scale Nylon Short punisher shaft
Old 07-10-2014, 08:39 PM
Rob - I too have the combine but did not start the process.
Q- what axel did you chose?
Old 07-11-2014, 02:57 PM
rc_farmer's Avatar
Master Builder
Hey Iz, It's the CC-01 axle
