Old 08-05-2014, 10:20 PM
PaulNZ's Avatar
PaulNZ PaulNZ is offline
PaulNZ is on a distinguished road
Default Logging Cab Guard
Hi all
here is my plan for an Aluminium Logging Guard for my current Build
I will route the uprights from 32 X 3 flat and use 7mm tubing for the outer section and 5mm tubing for the inner bars.
Two spot lamps from a 4x4 will be used on the two small brackets at the top.
it will sit on two 20 X 12 angle that will slit between the fuel tank brackets.
a piece of 10 X 15 channel with a section slotted out will sit on top of the uprights, this is where the trailer will rest when on the back of the truck.
Old 08-17-2014, 07:23 AM
PaulNZ's Avatar
Default Re: Logging Cab Guard
All the pieces are made, now just to ali solder them together.......never done this before so I hope it goes ok
Old 08-17-2014, 07:58 AM
kaptain Jack's Avatar
Very nice.
