Old 08-23-2014, 08:29 PM
rctrucker2's Avatar
rctrucker2 rctrucker2 is offline
rctrucker2 is on a distinguished road
Default Help with MFC-01
Sorry for the newbie question but I can not seem to locate the negative side (black wire) of the plugin on the MFC-01 for the servos. Is it the outside post next to the edge of the unit or inside post? Thanks for the help.
Old 08-23-2014, 09:08 PM
mavrick0 mavrick0 is offline
Default Re: Help with MFC-01
Black goes to the outside. If you need to test it use one of the servo wires on the MFC. The futaba style end will only plug in one way unless of course you've cut off the piece molded onto the servo connector.
Old 08-23-2014, 09:26 PM
rctrucker2's Avatar
Yes, I see now. The connector can only attach one way with the tab. I was looking in the directions for guidance before I started to plug anything in. Thank you very much, you were a big help.
