Old 09-04-2014, 08:50 PM
cosworth34677's Avatar
Default dump truck angle problems
ok i just redid a truck of mine and added a dump bed to it that was longer then the old one. know i have a angle problem, the ram doesn't sit low enough to push up on the bed. it just pushes it back and binds. so what do you do when you run out of room and cant go any lower with the mounting point?
Old 09-04-2014, 08:56 PM
Default Re: dump truck angle problems
Pics we need Pics
The length of the bed has nothing to do with it not lifting. You have changed something in the geometry to make it not dump any more.
Old 09-04-2014, 09:01 PM
well the bed sits lower then the old one on the frame. and the ram sit about a half inch back from the old setup
Old 09-04-2014, 09:24 PM
Then move the bed back up then you will get the angle back.
