Old 10-14-2014, 05:43 PM
Default King Hauler 6x6
It's time to build another truck
Surprise, surprise: blue King Hauler
I need a 6x6 to pull the big dump trailer on sand and gravel. This build will use a RC4WD R2 gearbox, with a LRP 12V TP II motor.
The truck has a bit of a lift, so I had to make some brackets to keep the driveshaft from falling out in severe conditions:
Since all the diffs will be locked, weight in the front is needed to be able to steer
Old 10-20-2014, 10:48 PM
Joe25's Avatar
Joe25 Joe25 is offline
Joe25 is on a distinguished road
Default Re: King Hauler 6x6
Liking it so far, did you just flip the axels to get the lift or was there some other modification done?
Make peace or Die! 1st Bn 5th Marines
Old 10-21-2014, 05:23 AM
What front axle are you using?
Old 10-21-2014, 06:07 AM
Made new brackets for the rear suspension. Drilled new holes for the front.
Truck axle with modification set from Der Getriebedoktor.
Old 11-02-2014, 12:17 PM
Some progress on the 6x6 hauler:
Mock- up:
Rear plate and cab protection from http://www.gardentrucking.com
Fine soldering
My self- designed and made tanks
http://youtu.be/ioMBuLzJgfo?list=UUq...l7ojb5iKU_ybig
Old 11-02-2014, 05:28 PM
Bracket ver 1.0. I might make another version, since I cut a bit too deep in the bend.
Tight fit
Light test:
http://youtu.be/JkO6eabPkX4?list=UUq...l7ojb5iKU_ybig
Old 11-02-2014, 06:38 PM
Ok I have to ask why you went to so much trouble to mount the suspension lower on the frame rails? Did you just need the frame rails higher than stock height?
Old 11-02-2014, 07:12 PM
I used my own brackets because I wanted better ground clearance and to have articulation in the front even with 6x6.
Old 11-03-2014, 05:56 PM
Good enough and the build is looking great so far, keep up the good work.
Old 11-13-2014, 03:31 PM
There has been progress
Bracket for the bumper
Bracket and cover for the lights on the chain rack, and spacer for the 5th wheel
One setp closer to being finnished
Old 11-20-2014, 04:18 PM
Slow progess during the weekend
Old 11-20-2014, 04:42 PM
A short clip: http://youtu.be/h3bNUKuYF2o
Old 02-17-2015, 11:52 AM
Got new aluminum axles from wtbcar.com Now I can both turn and drive in the sand.
Old 02-17-2015, 08:44 PM
Emil , i like your truck. Cool short wheelbase and tough looking.
if you determine that the cable tension is too high. The axels apart and investigate hoe they are made. I had similar issue and found that the manufacturer had springs inside and a torsion spring outside on the actuator. I remov ed the outer torsion and flipped my cable set up. ALSO Double CHECH The Gear Mesh On The Pinion And Ring gear. Mine stripped out way too easily.
Old 02-18-2015, 01:22 AM
Gibbs98 Gibbs98 is offline
Gibbs98 is on a distinguished road
Really admired your truck. super cool photos and videos.
