Old 11-10-2014, 12:09 AM
Daveroo Daveroo is offline
Daveroo is on a distinguished road
Default PMD GRU installation
Hello,
i have the GRU from PMD/garden trucking.com and i need to ask..the long screws/bolts that lock to the frame..do you drill out the hole some to let it slip through?..and which hole should it really be in?..i have the Tamiya Freightliner EVO..or Cascadia..also,using the kit from garden trucking,when cutting the shaft,just use a hacksaw and file it smooth?..or are there any tricks i should know?..
