Old 11-25-2014, 01:46 PM
Stuart's Avatar
Stuart Stuart is offline
Default Liebherr 944B
I've been waiting and saving for a long time to buy an excavator and its finally arrived, shame its damaged, see rant here
This is what i bought:
Should load the MB nicely (once the booms fixed of course!)
I've played around with the radio and added a few mixes so the pump only comes on when the sticks are moved, although the futaba fx-20 seems very limited when compared to my Taranis so may end up swapping it over.
I have a few mods in mind, such as a sound unit etc but need to save up some more and wait until its fixed.
According to premacon and ths,
"Boom and stick are made of aluminium, hard PVC and Pertinax in a layer system with the layers glued and screwed together"
Has anyone tried to machine this?
Cheers for looking
Stu
Old 11-25-2014, 01:56 PM
Default Re: Liebherr 944B
A very nice machine! The German models are reliable.
Old 11-27-2014, 12:45 AM
Congratulations Stu on a very fine purchase.
I feel your pain about the damage caused by the carrier, hopefully proper compensation is made and you can get this beautiful machine back in 1st class working condition.
Your hydraulic mixes, I'm not familiar with the Premacon models, but I do believe they use the same 0,3ml/rev Jung pump that my Fumotec models use with a big brushless drive motor? The initial Amp draw just to start that brushless motor continually will create excessive heat build up within your esc & then the thermal protection will kick in & time out the esc till it cools. It's better to have at least 20% motor activation at all times of intermittent digging. Shut the pump off via a switch when the trk is full.
Old 11-27-2014, 01:56 PM
Stuart's Avatar
Thanks Joe and your right about the type of pump/motor, I wondered why it cut out after a short while
I have the pump on a rotary knob as well as the mixes so can switch it on first and then let the mixes ramp it up when needed.
Its quite noisy with the pump running but I've found out this is due to vibration through the base plate, its solid mounted at the mo and was wondering about some kind of rubber mount?
Its so much quieter when unbolted from the base. I don't have much room to raise the pump though.
I've ordered a couple of 4000mah lipo's, what sort of run time would you expect with the pump running all the time?
Really pleased with it so far, hydraulics are very smooth and can't wait to do some diggin, just got to repair it first!
Old 11-28-2014, 03:30 AM
I use 4s 5000, easy digging is over an hour, hard digging about 40-50 minutes.
The latest models from Fumotec have rubber feet about 8mm tall. If nothing else shorter available, I'm sure you could cut out a square piece of rubber from tractor tire tube, the type that are filled with chloride as they much thicker than a car tire tube. But maybe a car tire tube would be enough.
Old 11-28-2014, 04:53 PM
Maybe it could be worth making these for our Varios Joe?
Less sound less vibrations, sounds good to me!
(sorry for taking up space in your thread)
Nice excavator you got there, too bad on the damage, hope you can work it out.
Old 11-29-2014, 01:14 AM
Rubber fuel line is quick and easy, I used it on my pickup's little air compressor.
Cheers, Neil.
Old 11-29-2014, 02:12 PM
Stuart's Avatar
Thats exactly what I was thinking of, have ordered some off ebay. Can you run these motors on a 4s ok?
I've put a piece of 3mm rubber under it for now, its a lot better but still get the vibration through the mounting bolts.
After about an hour last night it looked like this:
Then spent this afternoon milling and came up with this (love my old bridgeport):
Even if/when I do get the compo, I'm fed up with Premacon/THS not answering emails so thought I'd give it a go repairing it.
I think once its bolted and glued in place then painted should look ok and will probably be stronger than the original, may even make a complete new boom in the future.
Not sure whether to make some brass bushes for the pivot or just leave the steel pin in the ally with a splodge of grease???
Now where to find Liebherr yellow, or do I go white
Old 11-29-2014, 05:37 PM
Bo Wallen's Avatar
Try this http://baumaschinen-modelle.net/en/reports/tips/colours
Old 11-29-2014, 07:13 PM
Good work on the repair .... I gotta get a bigger mill someday.
How about a picture of the end of the boom where it is cut?
Premacon & THS split more than a yr ago.
My Fumotec models use an ABS bushing in the two plates - the cradle that the boom fits too. You probably should consider doing something to prevent oblonging holes.
My 850 is running 4s, but the pump & motor have a belt reduction of 2,5:1. On 4s the pump is spinning approx. 4000rpm. I see your model is direct drive with no gearhead reduction. I have had no problems running the pump @4000rpm, I don't know what the limit is, but perhaps you could check the current rpm your's is rotating and go from there. From what Premacon model excavators I have seen run in videos, the hyd movements seem too quick as it with those small boom/stick configurations & small bore/short stroke cyls.
I don't think you'll need 4s, and I don't intend to use 4s either in my smaller Fumotec 490 hoe - as the bores are considerably smaller vs the 850 cyls @18 (B&B) & 21mm(S).
Old 11-30-2014, 09:30 AM
Thumbs up Re: Liebherr 944B
Hello If I was you and went through all that trouble I would definitely put in Brass bushings. You have gone this far and it is apart so do it right now. Ed
Old 11-30-2014, 12:44 PM
Stuart's Avatar
Thanks for the paint link Bo.
Here's a pic of the boom after cutting with the hacksaw:
Got it drilled and tapped today:
Am going to fit some brass bushes, it makes sense to do it now, may try to salvage the original first before making some.
Yeah I know that premacon and THS split, I've emailed them both but no answers yet although I did get a response from Premacon through this forum at the beginning of the week, nothing since.
Mine is 2 yrs old and was sold by"Liebherr-modelle" and has "THS" engraved inside the body parts:
I was just curious about the 4s, I think your right that mine will be fine on a 3s, the hydraulics seem plenty fast enough, I will check the motor rpm when its back together.
Cheers
Stu
Old 01-03-2015, 03:27 PM
Cheers
Stu
Nice job on the boom fix. I think its even stronger than original.
I just came across the difference between THS and Premacon 944b and can be seen here: https://translate.google.com/transla...868&edit-text=
Old 01-03-2015, 05:07 PM
apfubar apfubar is offline
Yup... I think however that is for newer machines than Stu's... Or mine...
Stu,
I'll be interested to hear how you go with the new pump if you go down that path.
Cheers,
Ap
Old 01-12-2015, 02:49 PM
Stuart's Avatar
Stu,
Cheers,
Ap
I think your right Ap, its for the newer models.
Found a buyer for my current pump/motor setup (my dad wants it for a project he's working on) so have ordered the new pump, will let you know once I get it.
Went to my local model club on Sat afternoon, the pump mounts make a big difference, you could hardly hear it over the bruder converts Video sorry for the music! twasn't me.
Cheers
Stu
Old 11-30-2014, 02:28 PM
Stu,
Liebherr Modelle is now know as Premacon
FYI on the pump...
There is a newer one out which is much quieter, Premacon has it on their website. If I recall correctly 3s is the maximum for this pump, and yes it works pretty well.
I am still running the older one as well... I must admit I never thought of the rubber blocks... I should have. But then the noise isn't too loud on mine, and when other trucks are running at shows and such, you definitely can't hear it.
I do recall another customer replacing their standard boom with a demolition one, if I can find the link I will pass it on. Finally I have the same THS marking on mine, as stated by Lil Giants THS and Premacon were working together for a while.
Cheers,
Andrew P.
Old 11-30-2014, 08:15 PM
Rakthi's Avatar
Rakthi Rakthi is offline
Great repair and interesting to see how those booms are made!
Since you are in France, why not give the people at Premacon a phone call? Faster than writing an email and waiting for reply.
Hope you get it sorted soon and at least get some compensation for the trouble caused by customs/shipper!
Cheers!
Stephan
Old 12-06-2014, 01:21 PM
Stuart's Avatar
Stu,
FYI on the pump...
Cheers,
Andrew P.
Any idea why the new pump is quieter? is it a different internal design or the drive system? or is just because its on rubber mounts???
Mines not super loud but noticible that its reverberating through the base plate, if you unbolt it and hold away from the base you will notice a huge difference.
I will shoot a before and after vid once my rubber mounts arrive.
Cheers!
Stephan
I'm at work when they are open and mobile reception here isn't great so its easier to email.
Got a response from Premacon this week, a new boom is 400 euros and the dipper cylinder is 200 euros.
Still waiting for oz post to get back with an answer re compensation, should let us know by wednesday next week.
So i've been continuing with my repair job, glued and screwed my new piece on, filled the screw heads and painted it:
Its not a bad paint match, liebherr don't use a RAL colour so used the nearest I could find, once cut back and polished should be ok me thinks. Just got to wait for it to dry now.
I want to add a filter to the hydraulic system, where should I plumb it in, on the return to tank or the suction side of the pump?
Also what would you recommend for hydraulic oil?
Cheers
Stu
Old 12-06-2014, 03:21 PM
Great job, it blends very well!!
Old 12-06-2014, 07:07 PM
Better than new I say!
