Old 12-20-2014, 09:44 PM
Snowman3725
Guest
Posts: n/a
Default Drive shaft set screws
Does anyone know the size and diameter of the set screws used to attach drive shafts to the rear axle input shaft? For tamiya King haulers. Looked high and wide and can't find any specs
Old 12-20-2014, 11:38 PM
Default Re: Drive shaft set screws
3mm
Old 12-21-2014, 12:14 AM
Snowman3725
Guest
Posts: n/a
I assumed they were M3, what about the length?
Old 01-02-2015, 04:16 AM
Serviceguyuk Serviceguyuk is offline
Location: Mostly a little world of my own but otherwise in the Bolton area in the North West of England
Serviceguyuk is on a distinguished road
Lightbulb Re: Drive shaft set screws
It's actually a 3mm grub screw but 4mm won't do any harm as it may give a little extra thread length for your thread lock to bind to.
The full spec is "M3 x 3mm DIN916 socket set grub screw plain cup point".
You guys in the US might find it difficult to get hold of metric micro fasteners so I found a guy here in UK on eBay that sells the stuff really cheap and I'm sure postage to USA won't be too expensive. I don't think I'm supposed to post links here so I'll send you a PM with the link. All his stuff is A2 stainless too so no worries about lousy plating coming off.
