Old 01-19-2015, 06:15 AM
Rimrock Rimrock is offline
Default Current alarm, for a motor
Hey,
Are there anybody here that are into electronic circuits?
I'm planning making a winch, and have an idea to connect a alarm to the motor that will give sound if the current draw exceed e.g 3A (12V), to protect a rather expencive motor from overload. This instead of a fuse.
it should be something similar as the LiPo alarms, but for current, not voltage.
Is it complicated to make?
Old 01-19-2015, 08:11 AM
Default Re: Current alarm, for a motor
Lots of telemetry stuff with radios, I don't know about a stand alone current alarm.
Old 01-19-2015, 09:20 AM
Bo Wallen's Avatar
This one might work http://www.eachbuyer.com/dc-dc-conve...UkiRoCvR_w_wcB
Bo
Old 01-19-2015, 12:58 PM
Have you looked at 12 volt circuit breakers at Napa or other parts stores?
Cheers, Neil.
Old 01-20-2015, 12:32 PM
Perhaps limit the voltage to have it stall when max amperage or torque is reached. Or build in an adjustable slip clutch on the winch drum for max torque needed.
Old 01-22-2015, 02:05 PM
Hi, thanks so far. I have not found a finished circuit on the marked yet, that has a 'current buzzer'. There are the cheap current testers e.g on ebay, with a diplay, 0-10A. I guess it's possible to make it from some drawings and a circuit board, but I am still looking. I find some small circuit breakers, for 3A, on ebay. This winch will be a part of a wrecker boom/unit. When the current will pass the max allowed, and circuit to break, or a buzzer to buzz, one quite possible need to walk over to the model and re-arrange something on the rigging anyway.
Old 01-22-2015, 02:38 PM
A slip clutch would been good, if I had room, put it's too compact
Old 01-22-2015, 04:28 PM
A buzzer or warning device is much more complex of a device compared to a circuit breaker. Using a breaker you also don't have to worry about not hearing the buzzer due to noise or other equipment around you?
It does get loud at RC shows with lots of trucks running around.
Not sure if they make small versions but on the 1:1 machines I work on, some are equipped with auto reset breakers. Those would be perfect for you.
Old 01-23-2015, 12:33 AM
5 AMP is the smallest, I have seen, http://www.littelfuse.com/~/media/au..._breakers2.pdf
http://www.delcity.net/store/Auto-Re...AEcBoCQETw_wcB
Cheers, Neil.
Old 01-23-2015, 05:55 AM
You are correct I agree to that, it sure can be noisy when out in the 'field' and it could be difficult hearing the buzzer.
I guess a auto reset breaker will be the thing to go for), and forget about any alarm. I see now that my breaker must not be larger than 2 amps, and I managed to find some auto reset ones with this value, where they sell parts for scale trains. After being tripped, they need some time for cooling down to reset, I don't know how long.
http://www.microminiatures.co.uk/aca...-Breakers.html
