Old 03-24-2013, 02:10 PM
SmallHaul's Avatar
Default Re: MORPOWER pump & valve
Current: 9amp that's not good.. that's going down the same road as the hk version.
What's the diameter & width of the gears Ed? Maybe we can guesstimate what the flow might be?
Agreed. 9amps would be a lot compared to liembach pumps, i measured the current draw on 4 machines that i have worked on using liembach pumps and 2.5amps is the most any of them pulled.
9amps would be ok though if it has 4 times the power of a liembach pump. It would just be overkill for smaller hydraulic machines.
Always nice to see more rc hydraulic components become available.
Thanks for posting pics Ed.
Scott
"No load is too Small"
