#441
plexiglass roof so you see backing in?
#442
Back up camera
#443
Funny you say that Joe. I just so happen to have been collecting some stuff for Windows that could also work for roof panels.
#444
#445
madman 24v drills can open anything LOL
#446
How are you going to get it to close?? will you be able to push it back down???
Thinking out side the box Mario.. Wayne |
#447
Thanks guys, I just used the drill for demo purpose. Once the garage is assembled I'm just going to drill a hole in the side wall so I can use a screwdriver to roll the door up. Or maybe a little hand crank.
To close just have to pull it down by hand.The main reason for the doors is to try and keep leaves, squirrels and anything else out of the garage when not in use. I could easily get carried away and install a servo to run the door with switches to activate when you pull up but I keep reminding myself to keep things simple and full time outdoor friendly ........ Manual operation is fine with me.
#448
Lol! Is Mr Nutters coming for a visit???
Cheers! |
#449
RW can bring him if he wants. He can stay in the garage
probably not a good idea though, mr nutters would get his *ss kicked by the big black squirrels that rule the backyard.
#450
The doors are done and working. 99 freehand cuts in each door but well worth the effort. The plastic doors work great.
![]() Now, on to the exterior work next. ![]() ![]() ![]() ![]()
#451
Just some mock up pics but coming to life. ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]()
#452
And i say.... GO FOR IT Mario it will ad to your amazing layout.
I will come bye for the final test and inspection later. ![]() Merry X-mas. |
#453
The overhead door idea is simply brilliant...gotta like it!!!
#454
#455
The building looks good Mario. I like the sprayed concrete look!
#456
Yes it does have a great stucco look to it, thumbs up Mario.
#457
Thanks guys.
![]() I finally got all the things I wanted done before putting this together and it's finally starting to take a more permanent shape. ![]() http://youtu.be/x2OxVkitIXo I'm glad the house wrap works because it turns out this corrugated plastic stuff is not easy to make clean accurate measurement cuts and it helps cover the mess in the corners. . Never the carpenter, always the material right? ![]() So now that I've learned from that, I have a new idea on how to build with this stuff. Next building will have one seam. And all walls in one continuous piece. here's what I'm thinking......... ![]() ![]()
#458
Merry Christmas Mario!!
Forget mr nutters, he is probably already been in someone's potpie !!! I'll move into the garage!! And any creatures there will be staying there!! No more tree rats in the house!! Lol!! Can't wait for summer, and to see whatever you have built!!
#459
Tree rat.... I'm anxious for next summer. Things are going to look a lot different next spring. I want to make a little neighbourhood. I've owned 3 houses in my life so want to build scale versions of them and my parents house I grew up in. Of course a Tim Hortons coffee shop and whatever else comes to mind.
#460
Nice work as always mario..the lights are a nice touch as well ..Dam i wish you didnt live so far away ..You East coast guys are really pulling things together ..merry xmas my friend
| Currently Active Users Viewing This Thread: 26 (0 members and 26 guests) | |
