Old 07-16-2016, 03:49 PM
modelman modelman is offline
Default Re: Ny-Lint Mobile Dragline Conversion
Jim-I like the way you made the lugs on the track pads but was just wondering why you made the tumbler so wide. I'm sure you have a plan. Have you wrapped the pads around the tumbler to see if they will work. I always had a problem with this part. I never quite figured out how to do this. I got close but never got it perfect.
Old 07-16-2016, 07:45 PM
Rvjimd's Avatar
Rvjimd Rvjimd is offline
Tom,
They wrap around pretty good, I am hopeful that they might work better than the old style I tried first.
I know what you mean about the width. I may be wrong, but to fit/clear the lugs on the pads I made them as wide as the base of the lug plus the width of the side walls of the tumbler.
Thought I was going to be testing by now but I busted off a 6-32 tap in the tumbler and screwed it up trying to get it out. Darn I hate breaking taps!
I have a replacement half finished, but got sidetracked the rest of the day getting camping gear ready for the trip out to Brownsville.
With any luck I will get to try one side Sunday.
Jim
Old 07-17-2016, 12:14 PM
Get some #5-40 taps Jim. They are smaller but the finer thread make it easier to tap.
Old 07-18-2016, 09:30 AM
Rvjimd's Avatar
Made some progress this weekend. Here is the new prototype drive tumbler just about ready to go back together for a test. I will make a new wider one with wider side flanges, once I see how it works. I moved the side rail out another 1/4" and made new lower idlers.
Jim
Old 07-18-2016, 11:59 PM
Rvjimd's Avatar
I am reworking the frame rails for my crawler, but, it has a twist in it. Here is a short video that should explain what I mean.
http://youtu.be/0Eqewf_Ekmc
Part of the reason I wanted to rebuild these parts was the same twist in the old parts.
I tried to carefully drill the two sides while clamped together in the mill vise.
I tried to carefully turn the spacers in the lathe. The order was...
Chuck the stock in the 3 jaw, center drill, drill center clearance hole to size.
Turn outside diameter down just enough T to make it round and concentric to the center hole.
Part off. I faced one of them to match the length of the first.
I DIDNT machine the inside mating surfaces of the bar stock.
If I loosen the clamping screws a bit and tweak it as I tighten it is better but I want to try and figure
out what I might be doing wrong.
Jim
