#81
#82
Did you say you were going to use a sequencing valve, or that you didn't plan on it? Without a sequencing valve, whichever section moves the easiest is gong to be the section that moves first. Path of least resistance and all that.
Don |
#83
I don't think there's room for sequencing valves. They should be located on the boom, or other wise I would need a ton of more tubing. I can adjust the movement sensitivity on each segment with a nylon set screws though. They are meant to adjust the side play of the segments. Will just have to wait and see how is going to work.
#84
#85
Awesome work, as usual, Ari!
Big iron is awesome! |
#86
BEEFY!!!
#87
#88
Darn...just Darn... the precision is just incredible my hat is off to you sir.
#89
#90
You gonna be using a brixl radio With that setup?
Jake |
#91
No, I got the Servonaut HS16 radio.
#92
Hi guys, it's been a slow progress with this, but I got something done.
I got the slew motor mounted, and made some brackets to mount the crane to frame. ![]() ![]() ![]() ![]()
#93
Beautiful!
#94
#95
#96
I got the bed pretty much done. It's all brass, except sideboards and posts. It's soldered together.
The sideboards and posts are removable. ![]() ![]() ![]() ![]()
#97
#98
Wow. That machining is beautiful.
Awesome looking truck
#99
Very nice!! Looking forward to seeing it in operation!
#100
A fantastic build, way beyond my engineering skills
| Tags |
| hiab, loader crane |
| Currently Active Users Viewing This Thread: 2 (0 members and 2 guests) | |
