I did build a lock for the gate as follows. First made lock arms from some .060 brass. cut two pieces of 1/8" dia. drill rod and silver soldered on the arms. Cut a piece of 1/4" drill rod and drilled and taped 8-32 right the way through. Made up and silver soldered on a brass arm to link up to the servo.
![]() Threaded the 1/8" drill rod 10-32 thread and installed it with lock nuts to keep the arm parallel and from turning ![]() Mounted small servo from Helli to the box hooked up the linkage and it worked. Last photo is the down stop switch for the screw drive. It has a diode bridge on it so it will reverse to go back up. ![]() Thanks for looking Rob |
i like the look of the saw marks on the ends of the plastic
they look like steel after being cut with a plasma cutter and a gas axe nice detail lol ![]() Threaded the 1/8" drill rod 10-32 thread and installed it with lock nuts to keep the arm parallel and from turning ![]() Thanks for looking Rob[/QUOTE] |
Thanks for all the comments on the build. The pintle is from PMD and I think it's a good product. May have to install a spring to keep the lock closed.. Never thought about the edge looking like a plasma cut but it does. Tried a lot of different methods for cutting styrene and ended up using the band saw with 18 tooth blade. It cut the fastest and left that edge. I'll do up a drawing for the switch and post it later.
Back on the dump box. After it was finished I gave it a coat of Modelmaster Chrome silver and made the overflow boards for some mahogany. ![]() In this photo you can see the servo for the tail gate latch. ![]() I also had to shorten up the cab floor. I worked it out and was able to fit in the 12 volt battery for the dump. Two esc's are for truck drive and dump ![]() ![]() Next up will be painting the cab. Thanks for looking Rob |
