Old 02-26-2012, 09:15 AM
civic83 civic83 is offline
civic83 is on a distinguished road
Default Re: li-po ?
i do it all the time, never had a problem. the mfu doesnt have an LVC (low voltage cutoff) so you just have to keep an eye on your levels. you could also plug in an aftermarket lvc between the battery and the mfu , it will automatically shutdown when you hit the cutoff voltage.
Old 02-26-2012, 03:01 PM
SonoranWraith's Avatar
It's a dry 115 degrees.
Default Re: li-po ?
You can def run lipo and I would run the novak cut off. It is cheap protection.
Old 02-27-2012, 11:36 PM
DoubleClutchin' DoubleClutchin' is offline
DoubleClutchin' is on a distinguished road
Default Re: li-po ?
Thanks guys. I figured you can but just wanted to make sure.
I drive a Pumpkin'
