Old 11-23-2013, 08:55 AM
unix unix is offline
unix is on a distinguished road
Default Wheeled excavator Liebherr A934
unix
Old 11-23-2013, 08:56 AM
Default Re: Wheeled excavator Liebherr A934
unix
Old 11-23-2013, 08:58 AM
unix
Old 11-23-2013, 02:45 PM
Very, very nice work! You are a true craftsman. Not only with your machining and metalworking skills, but also with your styrene, brass, and soldering skills. The counterweight is very impressive. Was it 3D printed, or CNC machined? I like the casting line / rib detail on it.
Old 11-23-2013, 02:55 PM
tc1cat's Avatar
tc1cat tc1cat is offline
Super Moderator
Impressive!! To say the least. Wish it were mine
LYNN
Old 11-23-2013, 03:23 PM
That is some very excellent work! Wow!!! Always liked wheeled excavators and this is a dandy.
Old 11-23-2013, 04:45 PM
kerst's Avatar
kerst kerst is offline
very nice! beautiful work!
Kerst
Old 11-23-2013, 07:37 PM
zookpower zookpower is offline
zookpower is on a distinguished road
that looks awsome as
Old 11-23-2013, 09:47 PM
Another "Home Run"!
Cheer's, Neil.
Old 11-26-2013, 02:23 PM
ptebbe ptebbe is offline
ptebbe is on a distinguished road
That is a great project! I like the use of the slip ring. Very creative way to put the model together. I'm working on a similar model of a CAT M322d.
I had a few questions:
1. What do you use to lower the stabilizer legs (linear actuator, etc)?
2. Where did you get your hydraulic cylinders (or are they custom made)?
3. Did you make this from plans or CAD drawings?
5. Looks like you used a brushless motor for your pump. What is the Kv and how many volts are you running? Is the mount custom made?
6. what size brass tubing are you useing, and how did you get the barbs on the ends?
Thanks! Paul
Old 11-29-2013, 03:55 PM
Thanks! Paul
Hi
1. linear actuator with Polou geared motor - custom made by me
2. custom made by me
3. yes, I draw myself in the Q-cad, and I cut on handmade cnc milling machine
5. this is Roxxy BL Outrunner 2824-26, 1380 kV, LiPo 2S (if you using 3S then kV must be 1100 - Robbe Roxxy BL Outrunner 2824-34), motor plate is custom made by me
6. tubing brass size is 12mm outer diameter and 10mm inner diameter
Best regards
unix
Old 11-29-2013, 04:44 PM
Dunga_CZE Dunga_CZE is offline
Dunga_CZE is on a distinguished road
What's the dark material you use? Teflon (PTFE)??
Old 11-30-2013, 02:30 AM
POM (Delrin)
http://en.wikipedia.org/wiki/Polyoxymethylene
Old 11-30-2013, 12:33 PM
Stuff's Avatar
Stuff Stuff is offline
very awesome build!
what was the drive train from?
my YouTube is -
Subscribe!!
My Facebook -
Old 11-30-2013, 02:32 PM
Originally Posted by Stuff View Post
very awesome build!
Modelcraft geared motor 30:1
http://www.conrad.de/ce/de/product/2...RB-35?ref=list
unix
Old 12-01-2013, 01:09 PM
update
unix
Old 12-01-2013, 06:26 PM
Did you add any ballast inside your blade?
Old 12-01-2013, 10:50 PM
Finster's Avatar
Finster Finster is offline
Really clean build. Awesome job. Are the axles from Conrad too?
Brian
Old 12-02-2013, 03:22 PM
Not yet, but I plan to
The axles are the Losi MRC 1/18
unix
Old 12-02-2013, 04:06 PM
Did you start with the green seals, then change to the blue? Or are you using both kinds together?
