Old 12-28-2010, 10:04 PM
Snochaser's Avatar
Default Anyone ever heat styrene?
I tried it today!
made a "mold" of the trucks hood I am building (out of some wood).... clamped the styrene to the mold and started heating.....and baam! a one piece hood, sweet! That worked great, nice smooth rolled edges too.
Anyone else ever tried it?
Ben
Old 12-28-2010, 10:08 PM
firefighter-1177's Avatar
firefighter-1177 firefighter-1177 is offline
firefighter-1177 is on a distinguished road
Default Re: Anyone ever heat styrene?
Sweet ill have to try that. That truck wouldnt be a p series would it.
Old 12-28-2010, 10:35 PM
casper's Avatar
casper casper is offline
casper is on a distinguished road
Yep use that method regularly .
Here's a link that explains my process:http://automodeler.kitmaker.net/modu...cle&artid=1243
Just in the process of making 3 different cabs, fenders, hoods and radiator shrouds for my own projects (all 1950's trucks ).
Definitely a very useful method to learn.
Roger.
"The Best Things In Life Are Self Made"
Brian in PA's Avatar
I'd rather be truckin'
I have heated 2 of my hoods that I modified with no problems. Maybe try heating it and take your time bending it, a little at a time? Good luck!
brian
Old 12-29-2010, 12:10 AM
Snochaser's Avatar
emmmmm no comment. Double secret!!!
Ben
Old 03-30-2011, 05:22 PM
Zimms Customs
Guest
Posts: n/a
Heat a little at a time. I use a heat gun and use the low setting (750 degrees). Plastic starts melting around 350 to 400 so it doesn't take long to heat up. The great thing about it is that when you heat it, you can reshape things over and over again, as long as you don't stretch the plastic out.
Old 03-31-2011, 02:38 AM
Car5858's Avatar
Car5858 Car5858 is offline
Yes works great. Just remember that any problem with the wood plug will show on the molded part.
Old 08-14-2011, 09:52 AM
Bsorenson79's Avatar
Originally Posted by Snochaser View Post
I tried it today!
Ben
Did you vacuum form it or by hand?
Old 08-14-2011, 12:19 PM
Snochaser's Avatar
Formed it by hand, be careful not to strech it as it bends.
