Truck Building Tech Covers mechanical and electrical components for truck modeling |
any chance of a close picture of the Pup dump trailer axle setup
thanx im gonna buy the turn buckles. how would you suggest i connect the chain to the turn buckle by screw and nut!!
Grabbin gears and Rollin wheels ! LETS BLOW SMOKE!! Member of the Central Plains Mini Truckers,and a Minnesota road hammer. To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. Flat bedders do it with chains and straps,but now im yanking 53's To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. |
Here is one and I will see if I can get some others this weekend.
![]() Travis
to attach the turnbuckle - go buy some link chain - check out the jewelery stores and the craft stores for some "chain" - use a larger link to attach a hook to each end - as well as each end of your chain.
Also - PMD and others have aluminum hooks that are casted .... They work nicely |
![]() Travis
#26
Have you guys got any tips for gate locks on dump boxes. Finished up the the screw drive and dump box, just trying to figure out how to lock the gate.
Thanks Rob |
#27
rob , here's what I did
![]() this is the lever that closes the latch when the bed comes down to rest on the frame . It takes some tweaking till you get it right , but it works like a charm ![]() ![]() lets see if the vid works ( i can't remember what the squeaking is ![]() ![]() IHSteve
#28
IHsteve. Thanks for that. Here I am thinking about servos and screw drive latches and sometimes a person works himself into a corner. That catch, you built is great and if you don't mind I'll change it a little bit and try to make one like it. The way it opens when the box lifts is what I'm looking for.
![]() Rob |
#29
no Problem Rob , I tend to get a little suffisticated myself
![]() ![]() IHSteve
#30
One version of a tailgate lock I've done.
![]() ![]() ![]() ![]() ![]() ![]() ![]() lift the box this much for the pegs to retract to release the gate door ![]() Simpler idea yet for tandem trk. ![]() |
#31
Lil Giants. Sure was asleep on that one. Thanks for putting up pictures of your method of locking the gate. I built the lock arms and and then when working on the rest of the linkage remembered that I had a crashed Helli with some very small servos. I pulled one out and it fit right between the box rails, no problem. Needless to say that's how it ended up, servo operated. But thanks guys for posting your ideas.
![]() Rob |
#32
The auto-mechanical way works pretty good, but sometimes the lock sticks with too much weight against the tailgate... usually when it's out of my reach, like dumping outside with me in the basement.
The servo lock is quick, clean and works every time. ![]() |
#33
#34
![]() Travis
AKA "00" Biddle RIP FreddyGearDrive 2-12-59/12-19-11 Last edited by fhhhstix; 02-26-2011 at 11:44 PM. |
#35
The below photo's is what i have done. I have used a flat bed trailer and turned it into a lead trailer and it was my first attemped on doing it. It's was cut with and hacksaw and grinder it's still not finished needs alittle more work to be done and even thinking of changing it into a curtain sider pan trailer to match the back trailer.
#36
Not bad at all for a hacksaw. Good work!
#37
Thanks mate. Yeah it was the only thing that i had on hand at the time.
#38
Here's how I built my tandem axle converter dolly;
8.5 inch frame rails 2 chassis crossmembers tandem suspension 2 axles 5th wheel mudflap mounts PMD tongue hitch PMD pintle hook (on trailer) ![]() frame rail tapered at rear; ![]() front plate; ![]() rear plate with tail light cutouts; ![]() finished dolly; ![]() ![]() under a trailer; ![]() single and tandem axle dollies; note 5th wheel kingpin placement of each ![]()
WILDCAT T&C Jim B. Colorado Springs |
#39
Hey travis this question is for you. I was wondering what type of springs those are that you used on the your trailer
Zakery
Got a custom semi and dump trailer build coming soon |
#40
Hey there, can someone please tell me what the measure off that? (the red line on the picture)
Thanks a lot, im trying to start my first trailer build eheheh Azorean |
Currently Active Users Viewing This Thread: 7 (0 members and 7 guests) | |
